Thursday, July 29, 2010
Home   |   Search   |   About AUGI   |   My AUGI   |   Join Now
Go Back   AUGI Forums > AUGI Technical (English) > Programming > Dot Net API
 Welcome, Guest.
Login
Join Now FAQ Members List Calendar Search Today's Posts Mark Forums Read
Dot Net API Working with AutoCAD's Dot Net API? Ask your questions here!
Reply
Thread Tools Display Modes
Old 2009-09-20, 05:09 AM   #1
nwecksler
nwecksler is infamous around these parts
Default Window State
Is there a way of making all windows Maximized so there is now flicker when cycling through document windows?
I've tried to set all active docs windows but they dont stay Maximized
    Private Sub MaxWindows()
        Dim objDocs As DocumentCollection = AC_App.DocumentManager
        For Each objDoc As Document In objDocs
            If Not objDoc.Window.WindowState = Window.State.Maximized Then
                ActiveDoc = objDoc
                ActiveDoc.Window.WindowState = Window.State.Maximized
            End If
        Next
    End Sub
nwecksler is offline   Reply With Quote
Old 2009-09-21, 04:09 PM   #2
nwecksler
Default Re: Window State
Thanks will look into this may be able to use this http://www.codeproject.com/KB/bugs/M...px?msg=3120888
Old 2009-09-22, 01:50 PM   #3
nwecksler
Tony can u share your implementation? understand if you cant. Thanks for your help!
Old 2009-09-26, 09:19 PM   #4
nwecksler
Thats cool I'll have a go sometime soon cheers anyways.
Old 2009-09-27, 03:50 PM   #5
nwecksler
Quote:
Originally Posted by tony.tanzillo View Post
If you're switching documents programmatically, you can avoid the flicker by sending a WM_MDINEXT window message to the document that preceeds the one you want to activate, but doing that is non-trivial.
Tony this is over my head but I have tried the following and still get the flicker
documents are already opened
Imports System.Runtime.InteropServices
    <DllImport("user32.dll", SetLastError:=True, CharSet:=CharSet.Auto)> _
    Private Shared Function SendMessage(ByVal hWnd As IntPtr, ByVal Msg As UInteger, ByVal wParam As IntPtr, ByVal lParam As IntPtr) As IntPtr
    End Function
SendMessage(objDoc.Window.Handle, WM_MDINEXT, ActiveDoc.Window.Handle, 0)
        ActiveDoc = objDoc
Old 2009-09-29, 03:12 PM   #6
nwecksler
Ok I will I'm just confused as the article is related to forms and controls not autocad windows... Ill play around. Im getting there tho my app is getting better everyday. cheers.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Thread Thread Starter Forum Replies Last Post
Do not Reset the State of the Prospector Window Civil 3D Wishes CIVIL3D-003 (Archived) 0 2008-05-02 06:45 PM
Opening Explorer Window with focus, on top of the AutoCAD window? amaser VBA/COM Interop 2 2007-05-21 06:50 PM
Assign a Layer State to a Sheet Set then use that Layer State when Plotting pgastelum AutoLISP 8 2006-10-11 08:36 PM
Return the text editing window to the way it was so a window pops up prodrafter AutoCAD General 11 2006-03-31 11:04 PM
Selection window/crossing window parallel to UCS acadwishlist ACAD-001 (Archived) 0 2005-11-15 06:06 PM
