Results 1 to 7 of 7
Thread: file size does not decrease when objects are purged from dwg
    2004-10
    7
    Default file size does not decrease when objects are purged from dwg
    This has been happening to me for a few months now and it's getting crazy.
    I maintain a system that converts 2D blocks to their corresponding 3D blocks on our network. It's an old but very reliable. The problem I'm now having is using the 3D model as a reference for the 2d wireframe (actually in 3d but is nothing but lines and arcs).
    I have been exploding the 3D models down to lines and cleaning them up but when I re-block them they have started retaining the original file size.
    I've tried all the usual suspects.
    -there are no hidden blocks in the drawing.
    -it's thoroughly purged
    -tried saving as every kind of file imaginable opening and re-saving.
    I'm talking about a file that started out a 500k but should be down to 50k when I'm done but there is no difference in the final size.
    using 2002
    any help would be greatly appreciated
    Earth
    9,805
    Default Re: file size does not decrease when objects are purged from dwg
    Can you post an example DWG here or email one to me?
    R.K. McSwain | CAD Panacea |
    2004-10
    7
    I sent a sample to your yahoo
    Earth
    9,805
    As I suspected....
    This drawing contains 47512 named layer filters.
    http://forums.augi.com/attachment.ph...id=28700&stc=1
    Removing the layer filters and saving it caused the file size to go from 4316k to 152k
    Here is a tool so that you can remove these layer filters.
    http://hyperpics.blogs.com/beyond_th...yer_filte.html
    2004-10
    7
    you are da man. Just goes to show ya.....well..... thanks alot
    2004-07
    Detroit Michigan
    2,508
    Removing layer filters makes a huge difference.
    I have started to notice layer filters in 2007 because of
    the changes to the layout manager.
    Have layer filters always been there?
    I haven't created any on my own.
    I am guessing I inherit them through copying objects
    from other cad files.
    Earth
    9,805
    Quote Originally Posted by Robert.Hall
    They used to migrate from drawing to drawing like a virus prior to r2004.
    Current versions do not pass NLF along like that any more and can alert you to an excessive number of existing named layer filters. See LAYERFILTERALERT system variable.
  1. 2012: Cannot Decrease Size of File
    By bt1101011 in forum AutoCAD General
    Last Post: 2013-03-18, 04:50 AM
  2. Purge: The existing purge command misses some stuff that could be purged from a file.
    Last Post: 2010-03-12, 12:28 PM
  3. Large file size with ole objects
    By dznytoy.183015 in forum AutoCAD General
    Last Post: 2008-06-12, 05:00 PM
  4. Large file size without any objects in AutoCAD 2002
    By jfujiwara.70911 in forum AutoCAD General
    Last Post: 2008-05-14, 09:31 PM
  5. Help locating objects that cannot be purged
    By fletch97 in forum AutoLISP
    Last Post: 2007-12-04, 01:01 PM
