Results 1 to 9 of 9
Thread: cannot explode block
    23
    Default cannot explode block
    I have a block which I cannot explode. The block has authoring elements so I have opened it in the block editor but cannot find a parameter to allow exploding. Where can I change this setting?
    100 Club JeffClark's Avatar
    2002-07
    South Jersey
    152
    Default Re: cannot explode block
    Could it be that it has different X and Y scales? Or maybe it is on a different XY plane than the current one?
    in the upper right corner
    3,507
    Quote Originally Posted by LynNV View Post
    Can you go into the standard "Block Definition" editor and find the block, and check off "Allow Exploding"?
    All AUGI, all the time arshiel88's Avatar
    2005-02
    Off the Grid
    560
    You can explode it via vba.
    Sub ForceExplode()
    On Error Resume Next
    Dim retBlock As AcadBlockReference
    ThisDrawing.Utility.GetEntity retBlock, basePnt, vbCrLf & "Select Non-explodable Block to Explode"
    retBlock.Explode
    retBlock.Delete
    End Sub
    If the cause of being unexplodable is just unchecking the "Allow Exploding" option while creating the block, that's easy. But if the reason is varying x,y, and z-scale, its a different story. If the resulting object is valid, then it can be exploded. For example, a circle inside a block is non-uniformly scaled, when exploded will be an ellipse-valid. But a non-uniformly scaled sphere, when exploded will result to a null object and therefore will be deleted. So it depends on the type of objects inside your block.
    2004-08
    Iron Station, NC
    3,198
    with nothing selected, the explodeable property should be listed in the properties palette. Otherwise, a LISP routine could also prevent exploding of blocks.
    2009-06
    Toowoomba, QLD, Aus
    74
    If I can only apply that to MTEXT and Dimensions
    0,0,0 The Origin
    8,570
    Quote Originally Posted by matthew.221135 View Post
    Mtext and dimensions can be exploded - or were you going into further detail with this?
    2005-02
    Off the Grid
    560
    Quote Originally Posted by jaberwok View Post
    I think he wants to uncheck it to prevent exploding.
    0,0,0 The Origin
    8,570
    Quote Originally Posted by arshiel88 View Post
    Doh!
    you're probably right.
  1. 2009: Block won't explode
    By Bill.Jensen in forum ACA General
    Last Post: 2014-03-08, 02:24 PM
  2. how to explode minserted block
    By mohsin_hafiz2002839758 in forum AutoCAD General
    Last Post: 2012-10-08, 11:50 AM
  3. Unable to Explode block
    By Jawwad Malik in forum AutoCAD General
    Last Post: 2010-05-28, 11:44 AM
  4. Explode(?) field after block insertion
    By dweber.134794 in forum AutoCAD Fields
    Last Post: 2008-01-21, 09:26 PM
  5. Explode block refernce
    By rcox898534 in forum AutoLISP
    Last Post: 2007-07-23, 05:31 PM
