Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Cannot Open, Created with a newer Version
  1. #11
    Tallahassee, FL USA
    3,665
    Default Re: Cannot Open, Created with a newer Version
    Quote Originally Posted by Darren Allen View Post
    Thanks for the info.
    No one has 2013. We get our ACAD from our network so we are all on the same page.
    I do understand the BAK process and did not have to do it. I did the work around suggested on the warning to convert to 2010 using True View. This is issue is still not resovled as this may happen again. Someone from AutoDesk should take this bull by the horns and tame it for the rest of the world. Afterall, these seats are not given away.
    1. - Open the folder in Windows Explorer => Right-click the dwg file and pick Properties. On the Statistics tab if you aren't the 'Last saved by:' then someone else did it.
    2. - Ten years ago our MIS set a limit on user space used on the server. I saved a large drawing on close and the limit cut the dwg file in half. No way to open or recover it. Feel your pain.
  2. #12
    2,095
    Stupid question time: is this a DWG version problem, or a vertical/AEC content version problem?
  3. #13
    2006-03
    San Cristobal, Guatemal
    439
    Quote Originally Posted by dgorsman View Post
    I'm thinking this would be a question for an AutoCAD geek...and not me...
  4. #14
    0,0,0 The Origin
    8,570
    You mention "ACADm2012" in post #4 - would this be AutoCAD Mechanical? Or something else?
  5. #15
    2006-03
    439
    Quote Originally Posted by jaberwok View Post
    ACAD Mechanical 2012
  1. Replies: 3
    Last Post: 2015-07-15, 03:35 AM
  2. 2011: "This drawing was created with a newer version of civil 3d..." Nag Screen
    By scott.jeffers in forum AutoCAD General
    Last Post: 2012-12-21, 05:51 AM
  3. 2011: Open a newer project
    By jjanis in forum Revit Architecture - General
    Last Post: 2012-03-28, 05:21 PM
  4. Replies: 15
    Last Post: 2006-11-23, 03:47 AM
  5. Open an R14 word doc in newer version of cad
    By mark.barberini in forum AutoCAD General
    Last Post: 2006-01-12, 04:17 PM
