Results 1 to 10 of 10
Thread: Regapp and Anno Scales
    I could stop if I wanted to CadDog's Avatar
    So Ca
    439
    Default Regapp and Anno Scales
    Hi everyone,
    I just wanted to touch on these two utility to see if anyone have any new information.
    I have been finding more problems this past year with users not know anything about this.
    What if anything are you doing to control and/or maintain this problems.
    Thanks and any information will be welcome and helpful.
    9,803
    Default Re: Regapp and Anno Scales
    Quote Originally Posted by CadDog View Post
    Utilities that run at drawing load that auto-purge this bloat. For the Anno-Scales, it deletes everything and restores defaults we specify.
    DGN linetype bloat is also auto-purged, although it's rare to run across this now. Most DWGs out there are clean.
    2,095
    REGAPPs get left alone, manually purged from time to time. I've had problems with a few applications that get cranky when their REGAPP isn't present. They're rarely a problem for internally created files.
    Annotation scales are handled automagically and intelligently i.e. each drawing has an idea of what should be there, and it will check any inherited from XREFs for the same name and values.
    5,714
    I use my AutoPurgeReg utility (free at Exchange, link in my signature) to handle all unused RegApps at drawing Open and Save automagically, and Autodesk's 'Cleanup Scales' utility to batch process folder(s) of drawing's Annotation Scales at once... Just be sure to set the 'scale list threshold' to 0 (zero), so you don't end up with duplicate Annotation Scales with same name.
    So Ca
    439
    Thanks BlackBox but before I install this utility I need ask.
    Has anyone else install this and if so how is it working for you?
    Sorry BlackBox I just want to make sure this utility has a little history of working before I install it.
    A few of our offices I recently have been helping have many problems with file size issues so I really need to take a second look at any I proposed to use as a fix.
    I my local office problems are small since most here use regapp and anno scale cleanup utility.
    I love that once install I won't need to worry about this issue so much...
    5,714
    No worries; questions are always welcomed.
    If you're referring to my app; that's been published in Autodesk's Exchange Apps store since September 2013 (2014 version), it's got a 5-star rating (although getting positive feedback is very difficult), it's been downloaded +1300 times, used in +/- 70 Countries, and I've been using it for my own daily plans production since 2011 version. If you're apprehensive (that's fine), perhaps try it out on a single workstation that you've already backed up, before utilizing on multiple. Good news, it comes with a money back guarantee! Haha Besides, you can always email if you've found an issue.
    If you're referring to Autodesk's Cleanup Scales app; it's fantastic too. The only real issue I have with it, is that it's a standalone app you've got to download from their KB page, and isn't either included with the official ACAD/C3D product installer, nor from your Autodesk Account. I use this LISP to make it available to users without having to navigate to the app's install folder to launch manually:
    https://knowledge.autodesk.com/suppo...r-AutoCAD.html
    https://knowledge.autodesk.com/suppo...2-AE-2018.html
    (defun c:CleanupScales (/ file)
      (if (setq file (findfile "CleanupScales.exe"))
        (startapp "explorer" file)
        (prompt "\n** File \"CleanupScales.exe\" not found ** ")
    HTH
    So Ca
    439
    Thanks BlackBox,
    I was worry you would take it the wrong way so thanks for the stats...
    Ya, I was planning on install the AutoPurgeReg just on my station to see how it works and
    also be able to answer any questions users have later.
    Scale list cleanup is less of an issue now but files coming from subs normally are cleaned up.
    I have a question on you lisp. How does CleanupScales.exe works if not on your local station?
    I did tried in the past to create a server load but it didn't work because it was looking for a .dll , if I remember right.
    Using this lisp would also help me make it easier for the users to clean up their scales and those on subs files.
    Lastly, Thanks again for understanding where I'm coming from, in wanting to make sure about the programs I tell ours users in my company about.
    5,714
    Thanks BlackBox,
    You're welcome; as explained in my email, I get it.
    I encourage everyone to take what they like from what I offer. Nothing more.
    As for CleanupScales.exe, step #3 of the ReadMe file explicitly states that the application EXE & resource DLL be placed in "the installation directory of your AutoCAD-based product."
    Cheers
    So Ca
    439
    BlockBox.
    I sometimes read to fast so I totally misunderstood this "I use this LISP to make it available to users without having to navigate to the app's install folder to launch manually:"
    I thought you had a way to eliminating the users need to install locally by being able to run this app from the local server...
    This lisp is nice but I have them place a shortcut for both apps on their Taskbar.
    Thanks BlackBox...
    By next week I hope to be able to tell them to remove the BROOM from the Taskbar...
    5,714
    Cheers dude; glad you got it sorted.
  1. 2016: Graphic Scales Intelligently Linked to View Scales
    By ASinclair in forum Revit - Platform
    Last Post: 2016-10-06, 12:54 AM
  2. 2012: Reset insert points of anno blocks for all scales?
    By Dave F. in forum AutoCAD Annotation
    Last Post: 2012-02-06, 04:07 PM
  3. Allow "Custom Views Scales" to be available in the Properties of "Hide in Scales corser than"
    By autocad.wishlist1734 in forum Revit Structure - Wish List
    Last Post: 2011-10-07, 01:25 PM
  4. ACA 2009 Display Configs and Anno Scales
    By CAtDiva in forum ACA Wish List
    Last Post: 2009-02-04, 10:04 PM
  5. Old Anno Scales
    By dzatto in forum ACA/AMEP Tips & Tricks
    Last Post: 2008-01-30, 04:32 PM
