Results 1 to 8 of 8
Thread: How to Rotate Cursor Hair without Any Changes to UCS?
    2006-04
    (getpoint "Anywhere on the Enter Key =>")
    1,160
    Lightbulb How to Rotate Cursor Hair without Any Changes to UCS?
    Hi ALL,
    In the early days, say back to R14, I knew an add-on program does this - rotate cursor hair by picking any straight line or block then cursor hair matches the angle of the line or block.
    It is cool because it does not rotate the UCS (world).
    Anyone has an idea?
    And has this been discussed in this forum previously?
    It would be much appreciated if you can help.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,095
    Default Re: How to Rotate Cursor Hair without Any Changes to UCS?
    Are you thinking about the Snap Angle?
    2006-04
    1,160
    Sorry, it is nothing about snap angle setting.
    Actually, with this add-on I can drawing a rectangle laying on the cursor hair angle & giving me true width and height.
    2002-12
    30
    I've always ran the "ucs" command and used the "view" option which sets the crosshairs in true x,y coordinates for that view (thru a model space viewport in a layout). Once I am done doing whatever needs to be true to that view I will run the "ucs" command again and reset it to "plan". I know it isn't exactly what you are looking for, but it is quick and accomplishes the true rectangle entry you are describing.
    9,803
    Lightbulb Re: How to Rotate Cursor Hair without Any Changes to UCS?
    Quote Originally Posted by ke.li View Post
    Your original post said "rotate cursor hair by picking any straight line or block then cursor hair matches the angle of the line or block. It is cool because it does not rotate the UCS (world)."
    How else would you do this - other than changing the SNAPANG?
    The RECTANG command includes a rotation parameter that allows you to draw a rectangle at any angle without having to rotate the cursor first.
    2007-10
    Abu dhabi / Philippines
    22
    Nice one RK, thanks!
    2006-04
    1,160
    Thanks for all your sharing.
    However, drawing a rectangle is an example.
    When trying place a LINEAR dimension, another sample, with a certain angle on a object, you will find what I really want. On the sample attached, you can see the results of linear dimension & aligned dimension.
    Also, with the add-on described, you can easily copy or move objects by specifying a distance. And more...
    9,803
    I guess I still don't see how rotating the cursor doesn't allow you to do all this also.
    Other than rotating the cursor - what else did this "add-on" do?
  1. Ability to adjust the size of the cross hair cursor.
    Last Post: 2019-06-06, 06:40 PM
  2. Rotate Point at Cursor
    Last Post: 2010-10-21, 02:14 PM
  3. Hair & Fur shadows?
    By craigbennett in forum 3ds Max - General
    Last Post: 2007-11-20, 05:59 PM
  4. How do you rotate the crosshairs on the cursor?
    By stephen.coff in forum AutoCAD General
    Last Post: 2007-04-17, 02:59 PM
  5. Trying To Plot (aka Pulling My Hair Out)
    By ryanmcin in forum Revit Architecture - General
    Last Post: 2005-11-09, 04:56 PM
