When I open my Autocad to try and open a DWG it asks me to enter the full file path. How do I get it back to the original setting of browsing through files?
Make sure FILEDIA is set to 1:
Command: FILEDIA
Enter new value for FILEDIA <0>: 1
Command:
Post back if that doesn't work.
Thank you. I knew that but was not smart enough to get a DWG open first from explorer. Once again thank you.
Also, in that situation, you can enter a tilde (~) at the prompt asking for a drawing name and it will bring up the dialog box, but doing so doesn't change FILEDIA for future operations.
HTH
Placing the following code into your ACADDOC.LSP file will help reduce this problem. It can still happen during the current drawing, but opening another drawing or starting a new drawing should return the FILEDIA system variable back to the expected setting.
Code:(if (zerop (getvar "FILEDIA")) (setvar "FILEDIA" 1))
Of course, this will not change the FILEDIA system variable. The next time you try to open a file you would need to enter the ~ again to get the dialog box.Originally Posted by timcreary
