Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: General chit-chat relating to thread "Breaking info on AutoCAD 2007"
    AUGI Addict sinc's Avatar
    2004-02
    Colorado
    1,986
    Default RE: Breaking info on AutoCAD 2007
    [ Moderator Action Mode = ON ] Please note, this thread has been "split" from thread "Breaking info on AutoCAD 2007".
    Please post comments relating to "Breaking info on AutoCAD 2007" here in this thread. [ Moderator Action Mode = OFF ]
    One of those says that the new Autocad requires a pretty hefty graphics card, but gives no specs on what's required.
    Does anyone know? I'm ordering a new computer even as I type this.
    Last edited by Mike.Perry; 2006-03-05 at 06:10 AM. Reason: Refer to "Moderator Action Mode".
    Williamsport, PA
    641
    Default Re: General chit-chat relating to thread "Breaking info on AutoCAD 2007"
    I have a little editing to do yet, but these tutorials will be available later this month.
    http://home.pct.edu/~jmather/content..._Tutorials.htm
    2005-07
    2,356
    Smile Re: General chit-chat relating to thread "Breaking info on AutoCAD 2007"
    Quote Originally Posted by richards.64879
    See attached FAQ's.
    Hope this helps.
    2004-02
    Colorado
    1,986
    Quote Originally Posted by Steve.Sanderson(UK)
    See attached FAQ's.
    Hope this helps.
    I think the video card I ordered will cut it - an nVidia Quadro FX540. I'm not completely sure - that PDF also says to see the list of supported video cards, which I haven't yet been able to find anywhere. But it's a 128MB workstation-class graphics card, so hopefully it's sufficient.
    I could stop if I wanted to H.Hunter's Avatar
    2005-08
    Somewhere, but not here
    241
    Seems like 3D has taken 2007 by storm. I don't do very mcuh 3D, but I do like the new Xref manager though. Looks much easier to handle xrefs.
    Active Member Jordan Truesdell's Avatar
    2016-01
    Virginia, USA
    91
    See attached FAQ's.
    Hope this helps.
    So, when they say "Intel 3.0GHz or greater", which 3GHz are they talking about? The old style "clock cycles means everything" Intel chips, or the new "We can do more in less cycles" Intel Chips, or the new "We can do more in less cycles, and we can put two cores on a single die" Intel Chips?
    And, while we're at it, why would they suggest "2GB RAM or greater" when the standard address space has a maximum of 2GB addressable, and the only way to get beyond that limit is to activate a special boot option...and that will only get you 3GB. Not that you have much room to grow anyway, since XP can only recognize 4GB of physical RAM.
    Sorry, the requirements have me scratching my head, especially considering the equipment I've seen at many A/E firms. Then again, maybe they're just longing for the old days when the equipment was far more expensive than the software.
    2001-12
    St. Louis
    5,407
    Unhappy Re: General chit-chat relating to thread "Breaking info on AutoCAD 2007"
    Quote Originally Posted by Jordan Truesdell
    And, while we're at it, why would they suggest "2GB RAM or greater" when the standard address space has a maximum of 2GB addressable, and the only way to get beyond that limit is to activate a special boot option...and that will only get you 3GB. Not that you have much room to grow anyway, since XP can only recognize 4GB of physical RAM. .
    hmm... bowing to user requests to make their recommendations higher (2006 required 512 ram), so the people using their software would have something concrete to justify upgrades? still using 512 here and feeling soooo slooow.
    Melanie Stone
    @MistresDorkness
    Technical Editor
    Digital Delivery Director Brian Myers's Avatar
    2003-02
    Stillwater, Oklahoma
    1,819
    Expected shipping dates according to an area reseller:
    AutoCAD® 2007 (March 23)
    DWG TrueView™ 2007 (March 23)
    Autodesk® VIZ 2007 (April 6)
    Autodesk® Raster Design 2007 (April 21)
    Autodesk® Design Review 2007 - formally DWF™ Composer 2
    Building Solutions
    Autodesk® Architectural Desktop 2007 (April 7)
    Autodesk® Revit® Building 9 (April 12)
    Autodesk® AutoCAD® Revit® Series--Building 9 (April 12)
    Autodesk® Revit® Structure 3 (April 12)
    Autodesk® AutoCAD® Revit® Series--Structure 3 (April 12)
    Autodesk® Building Systems 2007 (April 19)
    [new product] Autodesk® Revit® Systems (April 19)
    [new product] Autodesk® AutoCAD® Revit® Series--Systems Plus (April 19)
    Civil and Mapping Solutions
    Autodesk Map® 3D 2007 (April 12)
    Autodesk® Civil 3D® 2007 (April 14)
    Autodesk® Land Desktop 2007 (April 14)
    Autodesk® Civil 3D® Civil Design Companion 2007 (April 14)
    Autodesk® Survey 2007 (April 14)
    2002-01
    4
    Question Re: General chit-chat relating to thread "Breaking info on AutoCAD 2007"
    Quote Originally Posted by Dilbert
    Building Solutions
    Thanks for that list. I'm marking my calendar now!
    Any news on when LT will be out? I hope to upgrade everyone at the same time.
    13,656
    Hi Richard
    That is due to the fact Autodsek have not "officially" posted those web pages into the public domain, yet.
    Currently only Beta Testers have access to the URL and they are under a NDA not to publish it until Autodek gives the green light.
    Mike
  1. Breaking info on AutoCAD 2007
    By Mike.Perry in forum AutoCAD General
    Last Post: 2009-10-14, 03:33 AM
  2. Replies: 12
    Last Post: 2009-01-30, 11:45 PM
  3. Replies: 15
    Last Post: 2007-10-26, 01:16 AM
  4. AutoCAD 2007 ignoring "Start In" shortcut property
    By sthedens in forum AutoCAD General
    Last Post: 2007-01-29, 03:44 PM
