Thread: File menu not behaving
    Member shona's Avatar
    2004-08
    Auckland, New Zealand
    16
    Default File menu not behaving
    I am having some issues with my AutoCAD / ADT standard menu.
    When I go to select any one of the functions listed below from either the "File" menu or the icon, the Command prompt states one of the following:
    Command: _save as
    Current file format: AutoCAD 2004 Drawing
    Enter file format [2000(LT2000)/2004/Standards/DXF/Template] <2004>:
    Command: _open
    Enter name of drawing to open
    <N:2005Projects5J08 234 Hobson St10%SK035J08-(--)301.dwg>:
    Command: _new
    Enter template file name or [. (for none)] <N:CAD
    TemplatesADC-A1-TBLK-LANDSCAPE.dwt>:
    What I really want is for the dialogue boxes to open!
    Even the Menuload function is reverting to command prompt input.
    It is probably really simple to fix , but as I am still learning this stuff, I don't know where to look to fix the problem.
    Under Options/system/startup: The "Show Startup dialog box"has been chosen. This has made no difference.
    I have tried reloading my profile, and the default profile but that doesn't work.
    I have tried cross referencing the "SETVAR" from this session to one copied earlier (when it was working). No differences found.
    It was working fine last night when I shut down, but this morning it is misbehaving
    Please, any help would be appreciated.
    Last edited by shona; 2005-04-19 at 09:50 PM. Reason: Adding another related fault
    I could stop if I wanted to Ron Oldenbeuving's Avatar
    2004-06
    Lewiston, South Australia
    291
    Smile Re: File menu not behaving
    From AutoCad help file -
    These system variables also affect the display of dialog boxes:
    ATTDIA controls whether INSERT uses a dialog box for attribute value entry.
    CMDNAMES displays the name (in English) of the currently active command and transparent command.
    EXPERT controls whether certain warning dialog boxes are displayed.
    FILEDIA controls the display of dialog boxes used with commands that read and write files. For example, if FILEDIA is set to 1, SAVEAS displays the Save Drawing As dialog box. If FILEDIA is set to 0, SAVEAS displays prompts on the command line. The procedures in this documentation assume that FILEDIA is set to 1. Even when FILEDIA is set to 0, you can display a file dialog box by entering a tilde (~) at the first prompt.
    FILEDIA and EXPERT are useful when you use scripts to run commands.
    Type in the filedia command, the default is probably set 0, change it to 1.
    2004-08
    16
    Red face Re: File menu not behaving
    Thanks Ron,
    I knew it must have been simple!!!
    The one thing I missed!!
    13,656
    Default Re: File menu not behaving
    Hi "shona"
    Please note I've *moved* this thread from the Software Forum to this one as I feel this particular Forum is a more appropriate place for such a topic.
    Thanks, Mike
    Forum Moderator
  1. Opening a file with a pull down menu
    By jflanigan in forum Dot Net API
    Last Post: 2011-06-27, 07:11 PM
  2. File Menu recent files
    By petebalf in forum Revit - Platform
    Last Post: 2009-05-09, 07:53 AM
  3. CREATING MENU BAR FOR LISP FILE
    By drsvsmani in forum AutoLISP
    Last Post: 2008-05-12, 12:06 PM
  4. How to write new menu file or update the existing menu in AutoCAD 2006
    By Partha Ghosh in forum CAD Management - General
    Last Post: 2007-09-30, 01:45 PM
  5. ACAD Menu file location
    By cad.33286 in forum AutoCAD General
    Last Post: 2005-01-06, 12:31 AM
