Thread: stretch 2 directions with 1 grip?
    100 Club sgoodmansen's Avatar
    2005-10
    Post Falls, ID
    118
    Default stretch 2 directions with 1 grip?
    I'm not sure this is possible, but I figured I'd at least ask. What I want to do is have a single stretch grip which , when stretched will also stretch the other side of the block simultaneously by the same distance, so the attributed text always stays centered.
    Any ideas?
    13,656
    Default Re: stretch 2 directions with 1 grip?
    Hi
    See if the following threads help...
    Centered text in dynamic blocks
    Dynamic block stretch in both directions from one grip?
    Have a good one, Mike
    2006-02
    74
    Add a second action to the first parameter to stretches the other side of the block. Highlight the new action and in properties, use -1 for the value of "distance multiplier" in the "overrides" tab. This will move or stretch (depending on your action) the entities the same amount in the opposite direction.
  1. Stretch same value in two directions (90 degrees apart)???
    By montero1 in forum Dynamic Blocks - Technical
    Last Post: 2014-10-28, 02:53 PM
  2. Stretch in XY directions
    By billscheltema in forum Dynamic Blocks - Sharing
    Last Post: 2008-07-09, 07:39 PM
  3. Stretch by grip, grip becomes longer than the actual block
    By cadconcepts in forum Dynamic Blocks - Technical
    Last Post: 2007-03-21, 08:23 PM
  4. Stretch Grip 150 feet away from inserted block?
    By zorroxxxx in forum Dynamic Blocks - Technical
    Last Post: 2006-10-27, 01:58 PM
  5. Dynamic block stretch in both directions from one grip?
    By kb3cxe in forum Dynamic Blocks - Technical
    Last Post: 2005-11-03, 10:11 PM
