Results 1 to 9 of 9
Thread: Large file size/ Many "Named layer filters"
    2003-06
    38
    Angry Large file size/ Many "Named layer filters"
    Hello all,
    I am running LDD3, AutoCAD 2002 on a Window 2002 PRO SP2 OS...
    Occasionally one of our files will get large in size (2MB) for no apparent reason. There is not enough data within the drawing to cause this and I just am not able to figure this out.
    Also.. not sure if it is related to this but there are many "Named layer filters" within this particular file I'm working with. Haven't been able to figure a easy way to remove all of these. But it sure seems ridiculous for so many "Named layer filters" to reside within a drawing file.... nor do I understand exactly how they all have gotten there. We do merge/paste drawings together form various sources, so I'm certain we are or have a issue to fix.
    Hopefully one uf you out there have a solutioon to our problem!
    Thanks, Mike
    13,656
    Default Re: Large file size/ Many "Named layer filters"
    Hi Mike
    Please note I've *moved* this thread from the CAD Mgmt. General Forum to this one as I feel this particular Forum is a more appropriate place for such a topic.
    Thanks, Mike
    Forum Moderator
    150700
    3,439
    Check out this thread in the FAQ Forum
    2003-06
    38
    Thanks Brenda... Purge_IDS worked like a charm!
    Earth
    9,805
    Quote Originally Posted by mserapiglia
    Hello all,
    Named Layer Filters.
    Thanks, Mike
    There is a lisp floating around the Internet by R.Robert Bell (search using google groups) that can delete them in mass. NLF's are carried around like a virus in versions prior to 2005. Copy/Paste, Wblock/Insert, etc. will propogate NLF. Until you upgrade, get the lisp, add a toolbar button to run this lisp, and get into the habit of running this tool before saving your drawings.
    Good Luck.
    13,656
    Quote Originally Posted by rkmcswain
    Please refer to the thread Brenda referenced in her above post.
    Layer Manager & Layer drop down are slow to open.
    The drawing file size if large, but there is hardly anything in it.
    Please refer to the following posts -
    RE: Slow Layers
    RE: Are junk layer filters added?
    RE: Importing & Exporting Layer Filters??????
    Have a good one, Mike
    Earth
    9,805
    Quote Originally Posted by Mike.Perry
    Please refer to the thread Brenda referenced in her above post....
    Thanks, but I'm not quite sure of your point. You simply repeated what I said in a more complex way (a bunch of URL's). The only difference is that it appears that the non-propogation of NLF started in 2004 rather than 2005.
    To the OP - note that 2006 includes an option to alert the user, and/or delete all layer filters upon drawing startup.
    13,656
    Hi
    Only pointed to those two threads as they contain the LISP routine written by Robert Bell that you referred to (ie. No need for a Google search).
    Was just splitting hairs and making people aware that the behaviour changed in AutoCAD 2004.
    Away, I meant no harm, no foul....
    Earth
    9,805
    Hi
    Ok, I didn't see the lisp, but I didn't read each one from top to bottom... No problem
    Was just splitting hairs and making people aware that the behaviour changed in AutoCAD 2004. Away, I meant no harm, no foul....
    Wasn't quite sure - 2004 sat on the shelf, then we went straight to 2005.
    Thanks.
  1. PDF Layer Filters available by "Plot" command?
    By actsrevolt in forum AutoCAD Plotting
    Last Post: 2010-09-18, 09:50 AM
  2. Curious - When is a file size "too big"?
    By nnguyen in forum Revit Architecture - General
    Last Post: 2007-09-14, 10:03 AM
  3. Need Help Deleting "Named Layer Filters"
    By rabitsarchitects in forum AutoLISP
    Last Post: 2006-09-06, 03:49 PM
  4. Drawing File Size "Norms"
    By artitech in forum Revit Architecture - General
    Last Post: 2006-03-10, 03:35 AM
  5. File size changed during "Save As"
    By dave.beyer in forum ACA General
    Last Post: 2005-04-28, 02:10 PM
