Thread: convert to bitonal image
    2008-12
    11
    Angry convert to bitonal image
    i hav a sid file, 1.5 GIG, converted it to a JPG 8 GIG, this is stripped . i need to plot it in black and white. when i attempt to launch the historgram the prograr crashes. any assistance would be apprecieated.
    civil 3D, Raster, 32 Bit
    TN/KY Area
    1,640
    Default Re: convert to bitonal image
    Try using the Change Color Depth "IDEPTH" then the Bitonal option under Process Image tools. Then you may need to use the invert under the cleanup tools.
    6,409
    Also, I find that if you do this in one step, i.e. go from a high depth down to 2, you may loose a lot of quality. The same with going from a high resolution to a low one. I sometimes do this in intermediate steps.
    LinkedIn
    2008-12
    11
    I get a fatal error C3D out of memory then it crashes.
    TN/KY Area
    1,640
    Quote Originally Posted by rschaff View Post
    That can be expected with a large image file on a 32 bit system. First turn off the 3 gb switch if you have it on. Second free up some memory and try to increase your page files. Clean out the user temp folder (Start > Run> tpye in "%temp%" w/o quotes, and delete all the files there you can. Then use the image options from the map tools and look at the memory tab, there's a few changes you can make there to boast the image performance temporary. Read the help on that tab and clear out that cache as well.
    6,409
    Check the size of your swap file too when you are looking for more memory.
    LinkedIn
  1. Raster design bitonal image for contour follower
    By swyman in forum AutoCAD Map 3D - General
    Last Post: 2010-09-01, 03:30 PM
  2. Convert to bitonal image
    By LanceMcHatton in forum Raster Design - General
    Last Post: 2006-04-27, 01:25 PM
  3. convert image into dwg
    By vergasov in forum ACA General
    Last Post: 2004-07-20, 10:12 PM
  4. convert image into dwg
    By vergasov in forum Revit - In Practice
    Last Post: 2004-07-08, 05:04 AM
