Results 1 to 10 of 14
Thread: Scaling in isometric View
    100 Club Binu Mathew's Avatar
    2005-11
    Kuwait
    187
    Default Scaling in isometric View
    Good morning......... I have a doubt about isometric drawing preperation of piping.Is it possible to prepare in scale?that is angle and other dimensions in scale.Is it NTS or SCALED?normally it is NTS(not in scale)?please reply as soon as possible.Thanking you....
    With best regards,
    0,0,0 The Origin
    8,570
    Default Re: Scaling in isometric View
    The concept of scale doesn't really apply in isometric views because the x and y scales are always different.
    in the upper right corner
    3,505
    Quote Originally Posted by BinuM View Post
    With best regards,
    You can draw it with a scale in mind, but it wouldn't have a scale called out.
    You just want to avoid someone putting a scale on it to get dimensions.
    I've done some isometric drawings where lines were drawn and dimensioned at the correct length, but the scale was stated: "N.T.S."
    All AUGI, all the time Richard.Kent's Avatar
    2001-01
    Albuquerque, NM, USA
    622
    Iso's can't be to scale since each line is foreshortened to the plane of projection. NTS is the only way to go.
    2000-01
    Seattle WA USA
    5,859
    Quote Originally Posted by Richard.Kent View Post
    Not entirely true. A 3D view set to one of the OOTB Iso (e.g. SW) can be scaled if you use a scale factor of 1.22474487*<desired scale>.
    R. Robert Bell
    Design Technology Manager
    Stantec
    2001-01
    622
    The OP asked about an isometric drawing which is a 2D drawing, so my comment stands. Even still, calling a 3D iso view to scale still seems wrong to me.
    0,0,0 The Origin
    8,570
    Quote Originally Posted by RobertB View Post
    x and y scales in the view plane will be different.
    3,505
    I agree and disagree.
    While I agree that you can't/shouldn't call out a scale for isometric drawings, you can draw them accurately and dimension them. The lines can be drawn to their actual length at their respective isometric angles. It makes the object appear a bit longer in those planes than it actually is, but can be done. This is actually discussed in a book I have from college, it's done to "simplify the drawing an Isometric view".
    See the enclosed drawing, I created this in the Isometric snap style.
    The lines are drawn and dimensioned to the correct lengths.
    I used a dimension style for plotting 1" = 1'-0", but I wouldn't state a "scale".
    ** The OP's question was (I'm paraphrasing) "Can Isometric drawings be prepared to a scale?"
    I say Yes you can draw them accurately (if needed) with a plotted scale in mind but you shouldn't call out a scale.
    But..if you're just doing a single-line (schematic) isometric drawing, it doesn't need to be done to any scale (1:1 ps is fine).
    That's all I'm sayin'
    2006-12
    Big "D"
    3,711
    Well, techinially it can be dimensioned correctly in CAD using the scale factor, but it can't be scaled. In other words, when it's plotted, a sub can't put a scale on it to get a dimension in the field.
    2000-01
    Seattle WA USA
    5,859
    Quote Originally Posted by dzatto View Post
    Wrong. Plot the attached DWF file and place a scale on it. That DWF is of a single 3D box, 1×4×9.
    R. Robert Bell
    Stantec
  1. callout a 3d isometric view
    By Kenny Gee in forum Revit Architecture - General
    Last Post: 2015-03-26, 06:42 PM
  2. isometric view from camera
    By ray salmon in forum Revit Architecture - General
    Last Post: 2008-10-08, 12:34 AM
  3. Isometric view
    By dzatto in forum ACA General
    Last Post: 2008-07-07, 05:28 PM
  4. How to rotate view from SW Isometric view
    By cargo33us120260 in forum AutoCAD 3D (2007 and above)
    Last Post: 2007-08-13, 06:52 PM
  5. 3D to three view w/isometric?
    By rennichd in forum AutoCAD 3D (2007 and above)
    Last Post: 2006-10-09, 11:13 PM
