Results 1 to 8 of 8
Thread: Changing the Color of the Display Paper Background!?
    2013-10
    Default Changing the Color of the Display Paper Background!?
    I need help with changing the color of the Display Paper Background. I am using the AutoCAD 2014. Under the Options/Display/Layout Elements/ Display Paper Background can be turn on or off. How can I change the color in PS?
    Cairo - no, not Illinois
    5,069
    Default Re: Changing the Color of the Display Paper Background!?
    no control provided to do that
    2015-11
    22
    Like this?
    0,0,0 The Origin
    8,570
    [QUOTE=reidcharley;1246142]Like this? ...
    Strange. That didn't work in the past.
    [Yes, I checked that it works now.]
    2015-11
    22
    [QUOTE=jaberwok;1246168]
    Quote Originally Posted by reidcharley View Post
    Like this? ...
    It's always worked for me. If I recall correctly, 2008 had the paperspace background set to some nauseating yellowish-ivory color as the default and I changed it back then, so the option has been around since at least then.
    (BTW, above example is from 2011)
    5,069
    OK, I thought the OP was talking about the background around the layout, the gray surrounding the edge of the paper
    Tallahassee, FL USA
    3,658
    Quote Originally Posted by WJM_Jr View Post
    Like cadtag said …
    Under the Options/Display/Colors… Sheet/layout you can change Uniform background. Unrelated to the Paper Background Display WJM_Jr asked about I believe.
    2015-11
    22
    Uniform background controls both the color of the layout background AND the paper background. If the paper background is checked to display and the OP is referring to the background behind it, then yes there is no control for that.
    Didn't cross my mind to think of the background behind the background
    maybe WJM will chime in and clarify if he hasn't been scared off...
  1. background color in paper space
    By rchampaia in forum AutoCAD General
    Last Post: 2014-01-23, 04:10 PM
  2. Changing background color via Lisp
    By cadconcepts in forum AutoLISP
    Last Post: 2011-02-07, 07:31 PM
  3. Changing Background Color
    By sinanbakir in forum Revit Structure - General
    Last Post: 2010-11-12, 04:42 PM
  4. 2011: Paper Space Background Color
    By chris4455 in forum AMEP General
    Last Post: 2010-10-22, 08:06 PM
  5. Replies: 3
    Last Post: 2006-10-24, 07:05 PM
