Thread: Digital PE Signature
    2012-04
    18
    Default Digital PE Signature
    Is there a way to place an electronic PE Seal onto a drawing and have it disappear when the file gets modified. I was told that there is a way to do this in AutoCAD, or do you have to do something with the PDF properties?
    9,805
    Default Re: Digital PE Signature
    Quote Originally Posted by wiegmanroger433258 View Post
    Are you referring to a digital signature on the DWG file?
    0,0,0 The Origin
    8,570
    or to CADVault?
    6,419
    No, the "PE seal" he is talking about is a CAD version a Professional Engineer's stamp.
    Roger, there is nothing in AutoCAD itself that can automatically do what you want. Perhaps when someone told you that, they were confused with the digital signature that RK mentioned? This is not something that is visible, but "digital" or mathematical. What John is referring to is to basically lock the dwg so that it can't be edited. What some have done with the seal is to make a block of the stamp and insert it and plot and then remove the "seal" block so that only the hard copy is the official version. I have written a program to do the latter. But what you want would require more custom code still that combines several technologies.
    LinkedIn
  1. ED419-1U: Connecting Digital Prototyping to Digital Fabrication
    By Autodesk University in forum Education
    Last Post: 2015-08-07, 05:30 PM
  2. Digital Signature Option
    By Dpump777 in forum AutoCAD General
    Last Post: 2006-05-01, 05:31 PM
  3. Digital Signature for Families
    By Charlie in forum Revit Architecture - Wish List
    Last Post: 2003-07-22, 06:29 PM
