Results 1 to 10 of 10
Thread: how to model a wall with a slanted top
    2010-02
    39
    Default how to model a wall with a slanted top
    How would I model a wall so that it looks like this in section without having it attach to a slanted ceiling?
    This is just an In-place mass.
    Orlando, FL
    1,049
    Default Re: how to model a wall with a slanted top
    It does not have to be an in-place mass. It could be a wall, with a reveal profile with the shape of a triangle, configured in the wall's properties.
    2010-02
    39
    I have never used a wall reveal and for some reason that option is actually greyed out in my Revit.
    Super Moderator CAtDiva's Avatar
    2015-10
    Where pedals spin to move wheels
    442
    Quote Originally Posted by katie.slover View Post
    Are you looking at a plan view or elevation? If you're looking at a plan view, switch to an elevation or section, then those options should be available.
    2004-05
    St. Louis, Missouri
    3,135
    Edit the Profile of the wall.
    2015-10
    442
    Quote Originally Posted by cliff collins View Post
    I think the OP wants to slope the top of the wall in section, not elevation.
    2013-03
    I think you should try to draw a reference plane slanted in an elevation view, name it if you want,select the wall and attach Top to the ref.plane.hope this help
    2016-01
    New Zealand
    60
    Interesting. My options for top constraints are in the wall type ... attach to ... level 1 OR level 2. I don't see where the named (and angled) reference plane is listed so cannot set top to it.
    2015-11
    Jo'burg SA
    4,512
    As stated previously: You cannot draw wall sweeps / reveals if you're not in a view showing the wall in its height. So change to a sectional view / elevation / 3d. Then you should be able to draw a reveal in order to cut a shape into your wall:
    As for attaching to a reference plane: No need to name the plane, but it is good practice. Just make sure you're in a section view of the wall, draw your plane, select the wall, click "Attach Top/Base" and click on the plane ... finished!
    2016-01
    New Zealand
    60
    Thanks. That's clearer now. Attach Top/Base is located in the RIBBON. It is a great feature, where one reference plane could control the tops of multiple walls.
  1. Able to edit profile on slanted wall while wall face is planar
    Last Post: 2013-08-11, 06:34 AM
  2. 2009: Slanted curtain wall
    By SBH1730 in forum Revit Architecture - General
    Last Post: 2012-03-14, 02:01 PM
  3. Slanted wall
    By jenny120797 in forum Revit Architecture - General
    Last Post: 2011-10-31, 11:31 PM
  4. Odd shaped slanted wall
    By chukarov in forum Revit Architecture - General
    Last Post: 2004-07-31, 08:53 AM
  5. slanted curving wall
    By urghh in forum Revit Architecture - General
    Last Post: 2004-07-31, 08:50 AM
