Results 1 to 6 of 6
Thread: SaveAs does not display a dialog box
    2005-08
    378
    Default SaveAs does not display a dialog box
    Using someone elses file and a system variable is set but i'm not sure which one it is.
    When i have gone to "save as" the dialog box isn't appearing rather requesting the address where to save the file on the tooltip. With some many variables it's hard to work out which one it is. Does anyone know which one it is ?
    Regards
    Stephen
    All AUGI, all the time zoomharis's Avatar
    2005-02
    Abu Dhabi (Native-India)
    506
    Default Re: SaveAs does not display a dialog box
    Quote Originally Posted by stephen.coff
    Regards
    Stephen
    Does it happens only with 'Save As' dialog box or is it common for all dialog boxes like 'Open' ? If so setting FILEDIA to 1 might help.
    har!s
    Earth
    9,804
    FYI, This was also easily found on the Autodesk KB [ http://support.autodesk.com ]
    http://support.autodesk.com/Getdoc.asp?ID=TS44816
    Have a good one.
    R.K. McSwain | CAD Panacea |
    13,656
    2005-08
    378
    Thanks guys, was the filedia.
    Thanks again.
    Regards
    Stephen
    2006-06
    Exactly what I was looking for, thanks guys!
  1. Bring back New and SaveAs dialog boxes
    By snorcisa in forum AutoCAD General
    Last Post: 2007-03-02, 05:26 AM
  2. SaveAs command does not display a dialog box
    By ntowne in forum AutoCAD General
    Last Post: 2006-08-25, 01:58 PM
  3. SaveAs dialog box
    By cchoupay in forum AutoCAD General
    Last Post: 2005-11-11, 10:33 AM
  4. Dialog box does not display when using commands like - Open / SaveAs
    By Glenn Pope in forum AutoCAD FAQ (Read only)
    Last Post: 2005-03-16, 05:06 PM
  5. Open/Save/SaveAs dialog behaviour
    By ntaylor in forum AutoCAD Wish List
    Last Post: 2004-06-07, 01:01 AM
