Results 1 to 6 of 6
Thread: Drawings open from command line not dialog box
    2004-11
    58
    Unhappy Drawings open from command line not dialog box
    When I open my Autocad to try and open a DWG it asks me to enter the full file path. How do I get it back to the original setting of browsing through files?
    AUGI Addict .T.'s Avatar
    Lost
    1,473
    Default Re: Drawings open from command line not dialog box
    Make sure FILEDIA is set to 1:
    Command: FILEDIA
    Enter new value for FILEDIA <0>: 1
    Command:
    Post back if that doesn't work.
    2004-11
    58
    Thumbs up Re: Drawings open from command line not dialog box
    Thank you. I knew that but was not smart enough to get a DWG open first from explorer. Once again thank you.
    Lost
    1,473
    Also, in that situation, you can enter a tilde (~) at the prompt asking for a drawing name and it will bring up the dialog box, but doing so doesn't change FILEDIA for future operations.
    HTH
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,100
    Placing the following code into your ACADDOC.LSP file will help reduce this problem. It can still happen during the current drawing, but opening another drawing or starting a new drawing should return the FILEDIA system variable back to the expected setting.
    (if (zerop (getvar "FILEDIA")) (setvar "FILEDIA" 1))
    2002-01
    jUSt Here (a lot)
    9,100
    Quote Originally Posted by timcreary
    HTH
    Of course, this will not change the FILEDIA system variable. The next time you try to open a file you would need to enter the ~ again to get the dialog box.
  1. Replies: 3
    Last Post: 2012-06-17, 09:42 PM
  2. Scroll Through Command Line Across Open Drawings
    Last Post: 2008-05-14, 12:48 PM
  3. Replies: 8
    Last Post: 2007-02-27, 11:37 PM
  4. Open command does not bring up dialog box
    By bmonk in forum AutoCAD General
    Last Post: 2006-05-25, 10:29 PM
  5. Open Command, 2 drawings at once?
    By JasonSelf in forum AutoLISP
    Last Post: 2004-09-15, 05:31 PM
