Thread: Incremental Saves - Isavepercent
    AUGI Addict jpaulsen's Avatar
    2002-04
    Colorado
    2,020
    Default Incremental Saves - Isavepercent
    Is there any reason that I should not set ISAVEPERCENT to 0, besides the fact that saves will be slower?
    I have done some research on the web and see that setting it to 0 has many potential benefits.
    • Smaller drawing size
    • Drawings open faster
    • Less chance for corrupt drawings (this mostly referred to R13 and R14 but who knows, might help in 2002 also)
    • Can fix a problem that may occur with file dates (I have not experienced this personally)
    The only negative I have read is the save times are longer. Big Deal. Why does Autodesk recommend ISAVEPERCENT be set to 50%? Is this just CYA to justify putting the command in there in the first place?
    2001-05
    Austin, TX USA
    2,201
    Default Re: Incremental Saves - Isavepercent
    I have mine set to 0. I don't even notice a difference in the time it takes to save. I think this is an outdated feature for when computers were a lot slower.
    2010-10
    2
    Hi thank you for every thing
    Earth
    9,805
    Quote Originally Posted by jpaulsen View Post
    Is there any reason that I should not set ISAVEPERCENT to 0...
    None that I know of.
    Ours are set to zero.
    R.K. McSwain | CAD Panacea |
  1. Incremental Option in Offset
    Last Post: 2012-12-23, 06:29 PM
  2. INCREMENTAL NUMBERING
    By gary m. schafer in forum Revit - Platform
    Last Post: 2010-11-10, 01:59 PM
  3. Incremental Instance Parameters
    By mmiles in forum Revit Architecture - General
    Last Post: 2010-02-25, 08:39 PM
  4. Incremental Alphanumeric with a Block
    By tskelton in forum AutoLISP
    Last Post: 2007-12-05, 07:02 PM
  5. Incremental File Saves
    By RookieFliss in forum Revit Architecture - General
    Last Post: 2007-04-07, 08:20 AM
