Results 1 to 6 of 6
Thread: can't open file from pull down menu
    2001-03
    19
    Default can't open file from pull down menu
    i can't open a file when i go -file - open - at the bottom of the screen i get - "Enter name of drawing to open (name of last drawing opened):" ctrl+o does not work also. i have exited, turned off the computer, reinstalled autocad but have not been succesfull so far. i'm running autocad 2002 on win 98. most of the pull down commands are greyed out and most of the icons won't work either. any ideas?
    2015-12
    Arizona
    2,478
    Default Re: can't open file from pull down menu
    Quote Originally Posted by thomas_raftery
    Turn on your FILEDIA, and CMDDIA and all should be well.
    Then export and save the current profile to someplace safe for when AutoCAD
    settings go astray, you can import this good profile you just saved.
    2001-03
    19
    Smile Re: can't open file from pull down menu
    it worked - thanks so much - you're a life saver
    2008-05
    Quote Originally Posted by mjfarrell View Post
    Have same prolbem...How do I find FILEDIA?
    0,0,0 The Origin
    8,570
    Quote Originally Posted by connie.184831 View Post
    You type it.
    2015-12
    2,095
    As a side note, when prompted for the file name at the command line you can respond with ~ to force the dialog.
  1. Double Click Pull Down Menu to Use Last Command Used from Menu
    Last Post: 2017-04-06, 01:09 PM
  2. Opening a file with a pull down menu
    By jflanigan in forum Dot Net API
    Last Post: 2011-06-27, 07:11 PM
  3. Pull Down menu dropping custom Pull downs one by one
    By lessZmore in forum AutoCAD CUI Menus
    Last Post: 2010-09-28, 10:34 PM
  4. Replies: 11
    Last Post: 2006-12-21, 01:39 AM
  5. Calling an Image Tile Menu from Pull-Down Menu
    By pinckney3 in forum AutoCAD CUI Menus
    Last Post: 2006-01-06, 06:42 PM
