Results 1 to 6 of 6
Thread: Lost "Last file opened path"
    2004-06
    4
    Exclamation Lost "Last file opened path"
    Back in the good ol' days (Friday) I could open a drawing and if I needed another drawing from this folder or any other I clicked on the handy "open file" icon and presto! There were all the .dwg files in the folder I had most recently opened in a box in center screen plus the option to browse other drives. Now in these darker times (Monday) the response I receive when I click on the "open file" icon is "Enter name of drawing:" and the last path used to open a drawing. If I haven't opened any drawings since I turned on my system the default path is "*.*". Now one else in our department is having this problem. I'm new to AUGI though I have been Drafting for about five years now using "2000". I sure hope someone out there has some ideas on this problem because I'm baffled. For any help, Thanks, Jamie
    2004-06
    36
    Default Re: Lost "Last file opened path"
    Do you still get the dialog box?
    Turlock, CA
    6,397
    Set FILEDIA to 1. Sometimes, if you cancel out of a lisp routine, etc, this may get set to 0.
    C:> ED WORKING....
    2004-06
    4
    Nope, only the request for a path. Similar "fileopen" command.
    Jamie
    2004-06
    36
    Is the drawing on your computer, or on a network in your office?
    2004-06
    4
    Congratulations!! You are the winner of one cold beverage of your choice. If your ever in San Angelo let me know. I'm buying. Thanks Jamie
  1. XREF "Saved Path" to "Found at" location
    By cadmancando in forum AutoLISP
    Last Post: 2012-01-18, 03:54 PM
  2. Replies: 13
    Last Post: 2010-10-05, 03:54 PM
  3. How to show "last printed" or "path" text in layout
    By cstone in forum AutoCAD General
    Last Post: 2008-11-29, 12:05 AM
  4. Convert a "IGES" or "STEP" file to a "SAT" file
    By jeff.garr in forum AutoCAD 3D (2007 and above)
    Last Post: 2006-11-20, 08:48 PM
  5. Can I use ObjectDBX to "read" an opened drawing?
    By bim3d in forum VBA/COM Interop
    Last Post: 2006-11-16, 11:04 PM
