Results 1 to 6 of 6
Thread: File Size
    3
    Default File Size
    Some of my CAD Drawings size become too big, I erased all object and purged, and removed all filter now the drawing is empty no image etc etc....but still the file size is 1.4 MB if anyone can help me... ?
    Thanks for everybody.......file size still the same ...when am audit...it found 13600 objects...the drawing is still empty....
    Stanly Edwin
    13,656
    Default Re: File Size
    Hi Stanly
    Please note I've *moved* this thread from the AutoCAD Customization Forum to this one as I feel this particular Forum is a more appropriate place for such a topic.
    Thanks, Mike
    Forum Moderator
    13,656
    Hi
    Have a browse of the following threads (especially take note of any links within) -
    increasing file sizes
    deleting layers
    Anonymous Blocks
    Have a good one, Mike
    13,656
    Quote Originally Posted by stanlyedwin
    Hi
    Could you please post an example drawing file so we can take a look.
    11
    Cool Re: File Size
    Have ya tried "undo"? That would bring all that stuff back.
    You say you removed everything from the drawing. What about starting a new drawing?
    We used to write what we wanted to keep off to a block (in modelspace). Then we could open up that block as a separate drawing, minus a ton of hitchhikers. Then whatever we wanted to keep from paperspace we would copy over via clipboard.
    When you purge, make sure you are on a layer you want to keep, and make sure you purge all nested items.
    Another thing you might try if you haven't already is to build the model in a separate drawing file, and then insert that as an XREF so you can manipulate it (copy and clip etc.) for differing purposes. We have found this really reduces file size.
    In short, a variety of solutions taken together should work just fine.
  1. PDF File Size
    By tonyv in forum CAD Management - General
    Last Post: 2011-04-27, 11:21 PM
  2. Allowable Forum file attachment types and their corresponding maximum file size
    By Mike.Perry in forum Forum Tips & Tricks (Read only)
    Last Post: 2007-05-28, 08:19 PM
  3. Obtain best Image file size for placing in drawing file
    By cadmecheng in forum AutoCAD LT - General
    Last Post: 2006-06-02, 07:49 AM
  4. shape file / dbf file size
    By gis.68227 in forum AutoCAD Map 3D - Wish List
    Last Post: 2004-08-20, 01:35 PM
  5. File size
    By Gerhard in forum Revit Architecture - General
    Last Post: 2003-11-22, 02:21 PM
