Saturday, November 21, 2009
Go Back   AUGI Forums > AUGI Technical (English) > Manufacturing > AutoCAD Electrical Support > AutoCAD Electrical - General
 Welcome, Guest.
Login
AutoCAD Electrical - General Ask your AutoCAD Electrical questions here!
Reply
Thread Tools Display Modes
Old 2009-05-20, 03:11 PM   #1
hinschberger
hinschberger is starting their journey
Default ACADE 2008 Design
I work at a Environmental Consulting Company in Canada and draw Electrical drawings for an Electrical engineer. I am trying to setup a simple control schematic for other projects with the JIC menu.
I have this pdf file and I want to create a general control schematic of a sludge grinder.
Question #1) Is the “TSH” (temperature switch) a child of the “TAH” symbol? What would be the parent symbol?
Question #2) Are all the push-to-test pilot lights components of the motor [1] and how do you link them with the motor when you don't know who the manufacturer will be?
Can someone please take a look and help me please. Thanks.
Barry H.
hinschberger is offline   Reply With Quote
Old 2009-06-05, 09:00 PM   #2
RenataP
RenataP's Avatar
RenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of light
Default Re: ACADE 2008 Design
Hi Barry,
TSH is a parent symbol represents the switch. TAH is a different parent – coil symbol with child contacts normally open or closed.
The push-to-test pilot lights have the 1 by them to indicate the wire number 1 where the three wire device is getting the third wire power from. Example of the High Temp amber push-to-test pilot light uses wire numbers 14, X2, & 1.
I hope this helps.
__________________
AutoCAD Electrical 2010
(ATP Instructor) soon
Autodesk Revit Architecture 2010
AU - 2008
RenataP is offline   Reply With Quote
Old 2009-06-11, 06:29 PM   #3
hinschberger
Hi Renata,
Thank you for your help.
Old 2009-07-06, 07:20 AM   #4
robert_smeallie
robert_smeallie is infamous around these parts
Barry,
The way to understand parents and children in AutoCAD Electrical is that a parent device can be a standalone item, that is one which operates electrically independent of other devices, such as a Pressure Switch, a Pushbutton, A Contactor coil, etc, which all have a 1 as their identifier. A child device on the other hand depends on another device for it to work, such as a contact depends on a coil being energised. In fact, most devices in a schematic which aren't relay contacts are usually parent devices.
So for example a Relay's Coil would have as its block identifier HCR1 where H means horizontal orientation in the drawing, CR is a Control Relay and 1 means it is the Parent Coil, while the relay's Normally Open contact would have as its identifier HCR21 where H means horizontal orientation in the drawing, CR is a Control Relay, 2 means it is a child of the Relay's Coil and 1 means it is a Normally Open contact.
Hope that clears things up a bit for you.
Robert Smeallie
Electrical Design Engineer
robert_smeallie is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
ACADE General hinschberger AutoCAD Electrical - General 0 2008-05-27 07:34 PM
AcadE on compressed network volumes csmith.134514 AutoCAD Electrical - General 0 2008-04-28 05:33 PM
Problemas c/ TITLE BLOCK UPDADE no ACADE 2008 gerson.eng Português - Inventor / AutoCAD Mechanical / AutoCAD Electrical 1 2008-04-17 09:56 PM
The next version of ACADE mako68 AutoCAD Electrical - Wish List 1 2007-12-15 08:46 AM
Combine DWG TrueView 2008 with Design Review 2008 bmorris.73689 DWG TrueView - Wish List 1 2007-09-04 06:48 PM
