Results 1 to 10 of 13
Thread: A routine that loads all of my other routines
    2006-12
    145
    Default A routine that loads all of my other routines
    Iv'e just read though all threads about loading routines but still didn't found an answer. The concept is to have 1 LISP (say, load.lsp) file which runs at AutoCAD startup and loads all of my LISP routines and some other routines (probably VBA). This would be as a common Startup Suite. If I want users to have a new routine I just add it to load.lsp file and they have it.
    What's the way to load another LSP or VLX file within LISP routine? I know (load "name of LSP or VLX"). Is there a way to point specific file in specific location, like (load "Z:\LISP\MyLispRoutine")?
    What's the way to load VBA routine file within LISP routine?
    I think I've already read about this concept before a while here in AUGI I just don't succeed to find the thread.
    Question to those who use acad.lsp, acaddoc.lsp or Start-up Suite to manage custom routines in multi-user environment: if you have 100 users and want to empower them with new super-time-saving-routine what do you do? Use shared acad.lsp, acaddoc.lsp or Start-up Suite? Or may be you use other methods how to empower your users with good tools?
    2015-12
    Utah
    69
    Default Re: A routine that loads all of my other routines
    Quote Originally Posted by Yancka View Post
    I use shared acad.lsp and acaddoc.lsp. Inside the acaddoc.lsp is the following code:
    (vl-load-com)            ; Load COM just in case it's needed
    ;;;  Routine: load_with_error       ;;;
    ;;;  Purpose: Load lisp files with error reporting and exit on error  ;;;
    ;;;  Arguments: FileList - list of lisp filenames to load   ;;;
    ;;;  Returns: Nothing of value      ;;;
    ;;;  If any of the files fail to load this routine will raise an alert box with ;;;
    ;;;  the error and each file that failed, then will exit the calling routine. ;;;
    (defun load_with_error (filelist / errors results)
      (setq
        results (mapcar (function
            (lambda (file) (vl-catch-all-apply 'load (list file)))
          filelist
      (if (setq errors (vl-remove-if-not
           (function (lambda (f) (vl-catch-all-error-p f)))
           results
        (progn
          (alert
     (apply
       'strcat
       (mapcar (function
          (lambda (er) (strcat (vl-catch-all-error-message er) "\n"))
        errors
          (exit)
    (load_with_error
      (list
        "Split"
        "logging"
        "QKeys"
        "Brd_ttlswap"
    (if (setq PersonalLisp (findfile (strcat (getvar "loginname") ".lsp")))
      (load_with_error (list personallisp))
    There are two keys to this working well. First is the QKeys file. This is a lisp file that contains aliases to my lisp routines. Here is a snippet from that file:
    (defun c:login () (load "log") (c:login)) ;   make an entry in tc.dat
    (defun c:logout () (load "log") (c:logout)) ;   make an entry in tc.dat
    (defun c:lli () (load "nlist") (c:lli)) ;   List nested entities
    (defun c:ltcp () (load "livetext tools.lsp") (c:ltcp)) ;LiveText Copy
    (defun c:ltd()(load "linetypescaledynamic.lsp")(c:ltd));LineType scale Dynamic
    (defun c:ltl () (load "r13ltscl") (c:ltl));lengthen ltscale factor of selected objects
    (defun c:lts () (load "r13ltscl") (c:lts));shorten ltscale factor of selected objects
    (defun c:lumberlayers()(load "lumber")(c:lumberlayers));set layers for lumber routines
    (defun c:mate()(load "attrib")(c:mate));Multiple attribute edit
    Note that each entry here loads a file then runs the routine. Demand loading in this way minimizes drawing load time while maximizing routine availability.
    The second section of code in my AcadDoc.lsp looks for a lisp file with the users login name and loads that file if found. this allows each individual user to create their own customizations and also allows me to build quick routines for the users on an individual basis for specific tasks.
    I do not specify a path to any of my lisp routines but rather add their path to the support search path.
    2008-11
    Fort Lewis, WA.
    124
    You can try something like this. This is a snippet of my ACADDOC.lsp
    ;;;This will create a 12" break.
    (defun C:b12 ()
      (load "\\\\Flfile\\Fort\\Cad\\Acad Master Files\\Routines\\Lisp Files\\ACADDOC_gap.lsp")
      (c:break12)
    ;;;This will create a 4" wide multiline.
    (defun C:M4 ()
      (load "\\\\Flfile\\Fort\\Cad\\Acad Master Files\\Routines\\Lisp Files\\ACADDOC_MLINE.lsp")
      (c:mline4)
    2008-02
    1,141
    i have a '_Subs' folder that has frequently used subroutines i've written. i have this in my startup lisp to load everything in that folder. you are more than welcome to it.
    ;loads all needed subroutines
    (if (findfile "C:\\AlanThompson\\LSP\\_Subs")
      (mapcar '(lambda (x)
                 (if (wcmatch (strcase x) "*.LSP")
                   (load
                     (strcat (findfile "C:\\AlanThompson\\LSP\\_Subs") "\\" x)
                   ) ;_ load
                 ) ;_ if
               ) ;_ lambda
              (vl-directory-files
              ) ;_ vl-directory-files
      ) ;_ mapcar
    ) ;_ if
    as far as loading specific routines, i either use the (load "BLAH") or (autoload "BLAH" '("BL" "BLAH"))
    hope this helps.
    2007-03
    57
    Loads lsp files from the specified folder and all subfolders
    (defun C:DWGRULL ( /              file_list      file&
                      z-files-in-directory          BrowseFolder
                      path           good           bad
    ;;; ==== EN ====
    ;;; DWGRU Load Lisp
    ;;; Command DWGRULL
    ;;; the Command for loading lisp (*.lsp) files from the specified folder, including all enclosed folders
    ;;; the Folder can be set obviously
    ;;; to Edit following lines in a code
    ;;; (setq path (BrowseFolder)); _ the Choice of a folder of loading
    ;;; the folder Task obviously
    ;;; (setq path "G: \\Work \\4ACAD \\MIP \\WORK \\DwgRuLispLib")
    ;;;; ==== RUS =====
    ;;; DWGRU Load Lisp
    ;;; Команда DWGRULL
    ;;; Команда для загрузки  лисп (*.lsp) файлов с указанной папки, включая все вложенные папки
    ;;; Папку можно задать явно
    ;;; Редактировать следующие строчки в коде
    ;;; (setq  path (BrowseFolder)) ;_ ;Выбор папки загрузки
    ;;; Задание папки явно
    ;;; (setq  path "G:\\Work\\4ACAD\\MIP\\WORK\\DwgRuLispLib")
    (vl-load-com)
      (defun z-files-in-directory (directory pattern nested /)
    ;| EN ============================================================================
    * function z-files-in-directory returns the list of files being in the set
    * directories
    * the Author: Zuenko Vitaly (ZZZ)
    * Parameters:
    * directory - a way to a folder for example "D: \\My documents \\ZEF \\Lisp"
    * pattern  - a template for example "*.lsp" or the list ' ("*.dwg" "*.dxf")
    * nested - to search in the enclosed folders: t (yes) or nil (is not present)
    * a call Example:
    (z-files-in-directory "D: \\My documents \\ZEF \\Lisp" "*.dwg" t)
    (z-files-in-directory "D: \\My documents \\ZEF \\Lisp" ' ("*.dwg" "*.dwt") t)
    ;| RUS ===========================================================================
    *    функция z-files-in-directory возвращает список файлов находящаяся в заданной
    * директории
    *    Автор : Зуенко Виталий (ZZZ)
    *  Параметры:
    *    directory  путь к папке например "D:\\Мои документы\\ZEF\\Lisp"
    *    pattern    шаблон например "*.lsp" или список '("*.dwg" "*.dxf")
    *    nested    искать в вложенных папках: t (да) или nil (нет)
    * Пример вызова:
    (z-files-in-directory "D:\\Мои документы\\ZEF\\Lisp" "*.dwg" t)
    (z-files-in-directory "D:\\Мои документы\\ZEF\\Lisp" '("*.dwg" "*.dwt") t)
        (if (not (listp pattern))
          (setq pattern (list pattern))
        ) ;_ end of if
        (if nested
          (apply
            'append
            (append
              (mapcar '(lambda (_pattern)
                         (mapcar '(lambda (f) (strcat directory "\\" f))
                                 (vl-directory-files directory _pattern 1)
                         ) ;_ end of mapcar
                       ) ;_ end of lambda
                      pattern
              ) ;_ mapcar
              (mapcar
                '(lambda (d)
                     (strcat directory "\\" d)
                     pattern
                     nested
                   ) ;_ end of z-files-in-directory
                 ) ;_ end of lambda
                (vl-remove
                  (vl-remove ".." (vl-directory-files directory nil -1))
                ) ;_ end of vl-remove
              ) ;_ end of mapcar
            ) ;_ end of append
          ) ;_ end of apply
          (apply 'append
                            ) ;_ end of mapcar
                          ) ;_ end of lambda
                         pattern
                 ) ;_ end of mapcar
          ) ;_ end of apply
        ) ;_ end of if
      ) ;_ end of defun
      (defun BrowseFolder (/ ShlObj Folder FldObj OutVal)
        (vl-load-com)
        (setq ShlObj (vla-getinterfaceobject
                       (vlax-get-acad-object)
                       "Shell.Application"
                     ) ;_ end of vla-getInterfaceObject
              Folder (vlax-invoke-method ShlObj 'BrowseForFolder 0 "" 0)
        ) ;_ end of setq
        (vlax-release-object ShlObj)
        (if Folder
          (progn
            (setq FldObj (vlax-get-property Folder 'Self)
                  OutVal (vlax-get-property FldObj 'Path)
            ) ;_ end of setq
            (vlax-release-object Folder)
            (vlax-release-object FldObj)
          ) ;_ end of progn
        ) ;_ end of if
        OutVal
      ) ;_ end of defun
      (setq path (BrowseFolder)) ;_ Choice of a folder of loading
    ;;; The folder task obviously ( Задание папки явно )
    ;;;(setq  path "G:\\Work\\4ACAD\\MIP\\WORK\\DwgRuLispLib")
      (setq good 0
            bad 0
      ) ;_ end of setq
      (setq file_list
               path
               "*.lsp"
               t
      ) ;_ end of setq
      (foreach file& file_list
        (grtext -1 (strcat "Load " (vl-filename-base file&)))
        (if (vl-catch-all-error-p
              (vl-catch-all-apply 'load (list file&))
            ) ;_ end of VL-CATCH-ALL-ERROR-P
          (progn
            (setq bad (1+ bad))
            (princ (strcat "\nError in file " file&))
          ) ;_ end of progn
          (setq good (1+ good))
        ) ;_ end of if
      ) ;_ end of foreach
      (vl-cmdf "_.Redraw")
      (princ (strcat "\nPath " path))
      (princ (strcat "\n Loaded "
                     (itoa good)
                     " Bad file "
                     (itoa bad)
             ) ;_ end of strcat
      ) ;_ end of princ
      (princ)
    ) ;_ end of defun
    (princ
      "\nType DWGRULL in command line"
    ) ;_ end of princ
    2007-03
    57
    Other exapmle: load lsp, fas, vlx, arx files from specified folder and all subfolders
    Functions BrowseFolder and z-files-in-directory in the previous post
    (vl-load-com)
    (if (or (not (getenv "*z_root_dir*"))
    (= (getenv "*z_root_dir*") "")
    ) ;_ or
    (setenv "*z_root_dir*" (BrowseFolder))
    ;_загрузка библиотеки лиспов и arx модулей с отловом ошибок
    ;_Library loading lisp and arx modules with catching of errors
    (foreach fil (z-files-in-directory
                   '("*.lsp" "*.fas" "*.vlx" "*.arx")
                   t
            (vl-catch-all-apply
              '(lambda ()
                 (if (= (strcase (vl-filename-extension fil)) ".ARX")
                   (arxload fil)
                   (load fil)
                 ) ;_ end of if
               ) ;_ end of lambda
            ) ;_ end of vl-catch-all-apply
          ) ;_ end of vl-catch-all-error-p
        (princ (strcat "\nError load file " fil))
      ) ;_ end of if
    ) ;_ end of foreach
    ;;(setenv "*z_root_dir*" "") ;_Clear *z_root_dir*
    If the way to a folder with programs is known
    (vl-load-com)
                    "Z:\\LISP\\MyLispRoutine" ;_ Type path here
    		           ;_ To use a double slash (\\)
                                 ;_instead of unary (\) in a way
                   t
            (vl-catch-all-apply
              '(lambda ()
                   (arxload fil)
                   (load fil)
                 ) ;_ end of if
               ) ;_ end of lambda
      ) ;_ end of if
    ) ;_ end of foreach
    2002-12
    77
    For company stuff, use a <company>.mnl to load all of the custom company lisps.
    If you load a company.cui / .mnu then it will automatically load the accompanying .mnl. This is just a lisp and it will get loaded with the menu.
    Dear Alan,
    I am a frequent user of your great lisps. Unfortunately I could not get the above to work. What I did was:
    Copy code to acaddoc.lsp as well as creating and running a runall.lsp file. In both I replaced your path "C:\\AlanThompson\\LSP\\_Subs" (all three instances) with "C:\Program Files\AutoCAD 2010\Support\custom_lisp". Of course custom_lisp is an existing folder with my favorite lisp routines. Since I know next to nothing about lisp I also tried to replace the single backslashes in my path wiht your double ones. Yet again without success.
    What do I do wrong? I really like the idea of such a "hot folder" (as these are called among adobe products) whose content is loaded upon acad startup (acaddoc.lsp) or running a single lisp (runall.lsp).
    Appreciating your response,
    Thanks and kind regards,
    Aurel
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,686
    Quote Originally Posted by marcaureljensen357148 View Post
    Dear Alan,
    Aurel
    As a fellow fan of Alan's code two things you can check first enter
     (findfile "C:\\Program Files\\AutoCAD 2010\\Support\\custom_lisp")
    at the command line and see if it finds your folder, second make sure
    (vl-load-com)
    is loaded first. Most heavy lisp users have it as the first line in Acad.lsp, it only needs to be loaded once so most of us don't put it in every routine.
    Personally I add my custom_lisp folder to the support path. That makes it eaiser to make sure dcl and other support files load without having to include paths. I keep the folder in "C:\Users\%username%\AppData\Roaming\Autodesk\" so It's there for whatever versions I have installed instead of seperate folders for each version. I see Alan does about the same for probably the same reason.
    Thanks Tom, Problem solved
    I have to admit that I have no clue what "vl-load-com" actually is, but it works just fine!
    Just one more question. I didn´t really get your point in the following. Do you have different versions of acad (e.g. regular and architecture) running? I always use the program-based folders instead of roaming because then settings apply to all win users at once (3 accounts on our machines for admin, me and my employee). Are the two options maybe just two ways to beat around the bush with individual pros and cons?
    Yet again thanks out of a (still!) snowy northern germany,
    Aurel
  1. Breakline routine loads then closes??
    By cwjean76 in forum AutoLISP
    Last Post: 2009-11-30, 10:51 AM
  2. Warning Routine Before AutoCAD Loads
    By Kevin Janik in forum CAD Management - General
    Last Post: 2007-08-04, 06:17 AM
  3. Replies: 9
    Last Post: 2007-06-13, 01:22 PM
  4. Replies: 2
    Last Post: 2007-04-20, 09:51 AM
