Saturday, November 21, 2009
Go Back   AUGI Forums > AUGI Technical (English) > Manufacturing > AutoCAD Electrical Support > AutoCAD Electrical - General
 Welcome, Guest.
Login
AutoCAD Electrical - General Ask your AutoCAD Electrical questions here!
Reply
Thread Tools Display Modes
Old 2009-06-26, 09:09 AM   #1
hendrikjw
hendrikjw is infamous around these parts
Question Pin List issues
Good Day
My pin List has a gremlin in it. When a place a relay coil & the contact of the relay on the same page the pin list links correctly. As soon as i place the contact on a different sheet as the relay coil the name of the relay links correctly but the pin list does not link. Is there anyone that might know what the problem might be.
hendrikjw is offline   Reply With Quote
Old 2009-06-28, 04:26 AM   #2
RenataP
RenataP's Avatar
RenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of lightRenataP is a beam of light
Default Re: Pin List issues
Pin list: When you add the contact on a different sheet, does the pins show up in the “Insert/Edit Child Component” dialog box?
__________________
AutoCAD Electrical 2010
(ATP Instructor) soon
Autodesk Revit Architecture 2010
AU - 2008
RenataP is offline   Reply With Quote
Old 2009-06-29, 09:26 AM   #3
hendrikjw
No it does not. When the contact is on a different page that the coil the pins does not show in the "Insert/Edit Child Component" dialog box. I use the Project button in the "Insert/Edit Child Component" dialog box to get the information when the coil is on a different page as the contact. The name on the coil is linked correctly but the pin list does not display
Old 2009-07-01, 05:09 AM   #4
RenataP
RenataP's Avatar
[FONT='Times New Roman','serif']So, the pins do not show up in the “Insert/Edit Child Component” dialog box after you have linked the child contact to the parent coil? [/font]
[FONT='Times New Roman','serif']Under the Pins, select List button. Does any information appear in the “Pin Numbers in Use” dialog box under the NC pairs or NO pairs? [/font]
__________________
AU - 2008
Old 2009-07-01, 11:48 AM   #5
hendrikjw
The information is also not listed under the list button in the "Insert/Edit Child Component". It also does not show anything under the "Pin Number in Use" section. The only thing that is linked or displayed/linked is the description on the coil
Old 2009-07-02, 06:38 AM   #6
RenataP
RenataP's Avatar
If you add pins, do they show up? If you add the same child component using that parent coil on the same sheet, do the pins show up? I am thinking that the coil part number that you choice is not in the pin list database.
__________________
AU - 2008
Old 2009-07-06, 10:59 AM   #7
hendrikjw
Yes when i add the pin manually they appear on the sheet. The pins list correctly if the coil and the contact are on the same sheet. But as soon as the coil and contact is not located on the same sheet the pin list does not link, The name of the coil is linked but the pin list does not. i have played around with the coil numbers but it seems to have no effect on the pin list linking the coil to the contact
Old 2009-07-08, 06:17 AM   #8
RenataP
RenataP's Avatar
That is a stumper! I cannot see why this would happen. You might have to pull out the big guns and ask Autodesk. Here is the website that they, Autodesk employees, answer. http://discussion.autodesk.com/forum...spa?forumID=38 (Autodesk Discussion Group)
__________________
AU - 2008
Old 2009-07-08, 09:44 AM   #9
hendrikjw
I am on the Autodesk Discussion group as well. I am dealing with Autodesk directly as well. we all know that this should work but for sum small reason it is not. Thanks for the help. I will post the solution as soon as i get it.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
2008 SCALE 1:100 xref xref xref xref- scale list issues Aphelion AutoCAD Customization 2 2008-11-21 09:17 PM
LIST Command doesn't list Attached by Layer Materials rbdome AutoCAD 3D (2007 and above) 2 2007-01-18 03:15 AM
ADT 2004 - List length of Lines without using the List command PHOTOS4ME ACA General 8 2006-12-27 03:05 PM
Revit Links/Family Hosting Issues (Wish List) mwenta Revit MEP - Wishlist 0 2006-07-27 04:11 PM
Autodesk Issues Tech Bulletin: Service Issues Affecting Revit9-Based Software jobcaptain Revit - Known Issues & Work-Arounds (Read only) 0 2006-05-02 06:25 AM
