Welcome, Guest.
| Revit - Platform The place for your general Revit questions or commentary that are appropriate for all versions of Revit. |
Thread Tools | Display Modes |
#1 |
I thought I should start a new thread regarding the DEBUG MODE for RAC2010 as it appears many people are going to be using it (for now).
OFFICIAL NAME FROM AUTODESK pre-2010, "Classic" user interface LIST HERE ANY ISSUES FOUND AND AND WORK AROUNDS Current Issues: Trim Command Has only one option Trim. Extend single and multiple are missing Dimension Command Has only one option Linear. Angular, radial, etc. are missing Workaround: select an existing Dimension or the desired kind and Create similar Workaround: Select an item. Click the make temporary dimension permanent icon and voila. credit to Callum Freeman Model Lines creation disabled Detail lines still working as normal Workaround: select an existing Model line and Create similar Save As missing from family editor Workaround in windows explorer or revits Open dialog box, copy the file and rename. Alternatively when asked to replace existing select no and the save as dialog box will open. Communication Center missing... Highlighted active page missing from project browser... SHORTCUTS For shortcuts to work, use your 2009 KeyboardShortcuts.txt found in the same folder as Revit.exe. Rename it to KeyboardShortcutsOld.txt and copy this to your 2010 folder containing Revit.exe. Please use the original thread Cracking 2010 for any additional comments surrounding this issue and leave this thread as an easy access utility for those brave enough to use the DEBUG MODE. Now using 2010, and loving it. Last edited by bulletproofdesign : 2009-11-18 at 12:43 PM. Reason: new issues |
#2 |
Yep, Trim is only one command now.
On a positive note, the new slope tool is available in classic mode: Drafting Tab - Spot Dimension - spot slope Cheers, Ian |
#3 |
Correct me if I am wrong, but it appears that Model Lines are disabled in Classic Mode. I don't use Model Lines too often but occasionally I need them. Fortunately it is still possible to use Model Lines in the family editor.
__________________
Revit 2010 - Autodesk commences "Operation Destroy Revit" |
#4 | |
Well Spotted, - this could be a deal breaker - mmm on second thoughts, a quick flip into ribbon mode using Truevis's app might not be such a hardship. Ian |
#5 |
I actually like this "feature." no more confusion of users over which lines are which, and detail lines seem to cause less damage when misunderstood...
__________________
Colin Stanley | Corgan Associates, Inc. "Kiss my Converse!" |
#6 |
You can get around this by selecting an existing Model Line and using the Create Similar command.
#7 |
Similar to the trim tool, the dimension tool is crippled. The five buttons on the options bar are not there, so you are limited to just dimension aligned.
__________________
Bret Thompson |
#8 |
Which can likewise be circumvented with Create Similar
#9 |
Not having all of the dimension tools is a deal breaker. Our office will be sticking with Revit 2009 for now. How long would it take Autodesk to make the minor improvements necessary to make the Classic UI fully functional? - Probably not long... Is Autodesk likely to do this? - Unlikely... Will users hate them because of this?.... Definitely!
__________________
#10 |
The following are broken from what I have discovered so far:
Model Lines Trim with Extend and Extend Multiple Dimensions other than Aligned For interest sake add the following to your Debug.ini: EnableShowMotion=1 This adds a Show Motion button to the NavBar. I haven't tried it out yet, but when I get a free moment I'll dabble a little. It may be broken, which is why it is not part of the shipping release, but so far the interface works seemingly correctly. DW |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| .NET code crashes in debug mode, but works otherwise. | rkmcswain | Dot Net API | 6 | 2009-07-27 02:34 PM |
| C# express debug | kerbocad | Dot Net API | 2 | 2009-02-14 04:56 PM |
| Debug Question | david.brissenden | VBA | 6 | 2008-08-19 08:18 AM |
| Debug Menu | Thomas Maleski | Revit Structure - General | 4 | 2008-04-22 08:35 PM |
| Running AutoCAD R13 in MS-Dos Mode, set-up ALT+TAB to switch to this mode? | ledgeprojects | AutoCAD Customization | 0 | 2006-02-26 08:48 PM |
