So I'm wondering if Fields can be used to count with perhaps a Lisp routine?? If you look at the attached drawing you will see what I'm after. And if not fields then perhaps some other method???
Right now in order to save time I've creating a sequentially pre-numbered series of Door & Window & Room Tags all with a range of invisible attributes for data extraction into schedules accordingly for quick placement into drawings, and I keep them in a block library file. Pretty normal stuff.
The cherry on the pie would be to only need to create one Tag block definition for each kind of Tag and place them on a custom Tool Palette [as I'm showing in the drawing] and as you drop any of the Tags into the drawing it recognizes the presence of other same type of Tags already in the drawing and then automatically increase the number value to the next available number for that Tag type.
Sort of like the Table column 'count' fill process....i think.
Since i'm not going to migrate over to Revit or ACA I'm wondering if someone has been able to figure out this little handy diddy in AC???
