Thread: Pixelated Rendering
    2004-01
    28
    Default Pixelated Rendering
    Hi all,
    I am creating the attached rendering with Max Design. This is the first time I am using daylight so I am wondering if it is part of the problem.
    My rendering is very pixelated. Granted, this is a test shot and the settings reflect that but I am still surprised by what I am seeing. Also, my ceiling is getting a weird affect with the lighting (look at the black portion with the rings around the lights)
    Any ideas out there? Here are my settings:
    Final Gather: Medium on the slider
    1000 x 600 resolution
    Soft Shadows Precision Multiplier 1
    Samples per Pixel: 1/4 / 1
    Filter: Mitchell
    Lock Samples Unchecked
    Jitter Checked
    Raytrace Acceleration: BSP2 (BSP results in crashing)
    Noise Filter High
    Caustics Off
    GI On, Multiplier 1, photons per sample 500
    Optimize for final gather checked
    Average GI Photons per Light 5000
    All objects generate and receive GI
    AUGI Addict METANAMORPHOSE's Avatar
    2008-01
    Lyon
    1,411
    Default Re: Pixelated Rendering
    Hi,
    The problem comes from the number of samples in the reflections of your materials (arch and Design)
    Bien à toi
    Michaël
    PS sorry for my bad english I'm french
    2004-01
    28
    Quote Originally Posted by METANAMORPHOSE View Post
    Hi,
    Bien à toi
    Michaël
    Okay so how would I go about fixing it? Increase the number of samples for each arch & design material? It is showing in my promaterials materials as well...
    2008-01
    Lyon
    1,411
    Hi,
    For ProMaterials, you can address them individually or together (looking at the pictures attached). The disadvantage is the computing time increases.
    For materials (arch and design) you can watch here (looking at the pictures attached)
    --> http://forums.augi.com/showthread.php?t=101387 (french forum)
    Michaël
    For me it is not necessary to put (in FG) on the Noise filtering very hight standard but very good, it does not go into your problem
  1. 2014: Rendering does not start, then rendering dialog disappears, then 3D view turns black
    By gabsimonelouise692565 in forum Revit - Rendering
    Last Post: 2015-06-02, 07:34 PM
  2. 2014: Walkthrough exports are pixelated
    By ChristinaB in forum Revit MEP - General
    Last Post: 2014-10-22, 09:22 PM
  3. Pixelated text in hidden view mode
    By andre.gawlik in forum AutoCAD General
    Last Post: 2007-08-10, 12:57 PM
  4. Rendered image produces pixelated shadows
    By stusic in forum 3ds Max - General
    Last Post: 2006-10-05, 11:54 PM
  5. Replies: 4
    Last Post: 2005-10-18, 12:58 PM
