Friday, November 20, 2009
Go Back   AUGI Forums > AUGI Technical (English) > AEC > Revit > Revit Architecture Support > Revit Architecture - Tips & Tricks
 Welcome, Guest.
Login
Revit Architecture - Tips & Tricks Got a hot tip? Share it here!
Reply
Thread Tools Display Modes
Old 2009-10-05, 05:31 PM   #1
Martin P
Martin P is shooting for the starsMartin P is shooting for the starsMartin P is shooting for the starsMartin P is shooting for the starsMartin P is shooting for the starsMartin P is shooting for the starsMartin P is shooting for the starsMartin P is shooting for the starsMartin P is shooting for the starsMartin P is shooting for the starsMartin P is shooting for the stars
Default RAC 2010 - Speedy UI.....
*****************EDITED AND UPDATED***************************
Refer to new "SPEEDY UI 2.0" thread for the completely finished article
http://forums.augi.com/showthread.php?t=108571
- and a demo AVI of it being used with mouse gestures to access each of the flyout menus.
Have added a few more options to open the menus for those without a windows key. And also the only works in Revit Line suggested By David Kingam - thanks
{ALT} X
{WIN KEY} Z
and `
will run the menus. I have also included gesture recognition software along with my Set of gestures I use for Revit and Autocad - in a folder called strokeit - awesome free software I love and has made my life easier for years. For me personally this is by far the quickest option especially when using a Wacom Tablet. Take a day and get used to it you will never look back...
If you downloaded the menu scripts on 5th october, I would suggest you scrap that and download the new one - its finished and all works.
If anyone adds to it, please post it here! I would really like to add a function to avoid even having to pick - ie a hover over picks for you. Beyond me at the moment though.... This was actually really simple to produce and took a day or 2 from having never done it before.
And thak you for the praise Have been away from here a while, thought I would arrive back with something nice I am still often using a Lisp routine that dbaldacchino posted for me years ago... So hope this in some ways repays your kindness to me!
***BUGS************************************
Finish sketch does not work on filled regions - the keyboard input differs - BUT it is possible to make this work by the button location and forcing the mouse to pick there which I will work on doing, pretty simple - however you will have to use the same screen resolution as me for this to work correctly - or alter the script to suit your own resolution....
Paint - (edit the script yourself to read as below - M was missing after {alt})
Mpaintface:
send {alt} Mpn
return
*************Future additions****************************
Finish Sketch / Edit sketch to work on ALL items including edit wall profile.
Make Menus transparent. (added to speedy ui 2.0 thread)
Make hover select item rather than pick (added to speedy ui 2.0 thread)
Make each flyout available on its own as Hotkey. (added to speedy ui 2.0 thread)
Any suggestions??
__________________
http://www.highplans.co.uk/
Last edited by Martin P : 2009-10-08 at 06:14 PM. Reason: removing obsolete version
Martin P is offline   Reply With Quote
Old 2009-10-05, 05:55 PM   #2
ws
ws's Avatar
ws has a bright futurews has a bright futurews has a bright futurews has a bright futurews has a bright futurews has a bright futurews has a bright futurews has a bright future
Default Re: RAC 2010 - Speedy UI.....
That is very nice with a Wacom tablet
__________________
William Sutherland RIBA
ws is offline   Reply With Quote
Old 2009-10-05, 06:36 PM   #3
Martin P
Yep, I go one too - Shame Wacom only give you one menu though No flyouts > Would have saved me loads of time!! I am pretty pleased with it so far. Will be finished tomorrow and post the final one to suit our office set up. Has taken a little over 5 hours to this point to do. - not counting learning time on Autohotkeys which was not huge.
Just got to try and work out how to avoid picking any commands at all. I want to "hover" to select each command rather than click - it is possible with Autohotkeys to do that, but maybe take a bit more knowledge than the very little I have..... Am hoping to be able to pick it out of somebody elses script.....
__________________
Old 2009-10-05, 08:18 PM   #4
truevis
truevis's Avatar
truevis is a beam of lighttruevis is a beam of lighttruevis is a beam of lighttruevis is a beam of lighttruevis is a beam of lighttruevis is a beam of lighttruevis is a beam of lighttruevis is a beam of lighttruevis is a beam of lighttruevis is a beam of lighttruevis is a beam of light
Good effort.
http://www.autohotkey.com/forum/ -- AutoHotkey Community Forum -- is a helpful place.
You could actually have it create the menus dynamically by reading the keyboard shortcut TXT file, first.
truevis is online now   Reply With Quote
Old 2009-10-05, 10:35 PM   #5
david.kingham
NavisWorks Moderator
david.kingham's Avatar
david.kingham is reaching for the moondavid.kingham is reaching for the moondavid.kingham is reaching for the moondavid.kingham is reaching for the moondavid.kingham is reaching for the moondavid.kingham is reaching for the moondavid.kingham is reaching for the moondavid.kingham is reaching for the moondavid.kingham is reaching for the moondavid.kingham is reaching for the moondavid.kingham is reaching for the moon
Wow this is so simple yet so useful. I never thought about using the menu commands in ahk.
I would recomend adding this to the top of the script so it only works if Revit is active
SetTitleMatchMode, RegEx
#IfWinActive, Autodesk Revit Architecture|Structure|MEP 2010 .*
__________________
David Kingham
The Neenan Company
BIM Manager Blog
david.kingham is offline   Reply With Quote
Old 2009-10-06, 12:45 AM   #6
mbalsom
mbalsom appears to be going the right way
Originally Posted by Martin P View Post
Ok,
To access all the commands we wanted you press the "windows" key and "Z" on your keyboard - could be any combo or key that you like, thats just the one that we picked
(the windows key is the one just below z on your windows keyboard)
For those of us who don't have a "windows"key, how can I try this app.
I'm using a "lefthanded keyboard" (keypad on lefthand side) and has on windows key.
Thanks
__________________
MB Drafting
NSW Australia
mbalsom is online now   Reply With Quote
Old 2009-10-06, 07:14 AM   #7
dbaldacchino
Count (Formula)
dbaldacchino's Avatar
dbaldacchino is a shining stardbaldacchino is a shining stardbaldacchino is a shining stardbaldacchino is a shining stardbaldacchino is a shining stardbaldacchino is a shining stardbaldacchino is a shining stardbaldacchino is a shining stardbaldacchino is a shining stardbaldacchino is a shining stardbaldacchino is a shining star
Awesome work Martin!
__________________
dbaldacchino is offline   Reply With Quote
Old 2009-10-06, 08:07 AM   #8
Mike Hardy-Brown
Mike Hardy-Brown's Avatar
Mike Hardy-Brown is reaching for the moonMike Hardy-Brown is reaching for the moonMike Hardy-Brown is reaching for the moonMike Hardy-Brown is reaching for the moonMike Hardy-Brown is reaching for the moonMike Hardy-Brown is reaching for the moonMike Hardy-Brown is reaching for the moonMike Hardy-Brown is reaching for the moonMike Hardy-Brown is reaching for the moonMike Hardy-Brown is reaching for the moonMike Hardy-Brown is reaching for the moon
Great stuff Martin!!!!
__________________
Mike Hardy-Brown
INDEPENDANT REVIT CONSULTANT
Visit my Homepage
Visit my Blog
"I begin with an idea and then it becomes something else."
Pablo Picasso.
Mike Hardy-Brown is offline   Reply With Quote
Old 2009-10-06, 08:50 AM   #9
Priit.L
Priit.L's Avatar
Priit.L is going the right wayPriit.L is going the right way
Thumbs up Re: RAC 2010 - Speedy UI.....
Awesome stuff!
__________________
Priit
Structural Engineer
Priit.L is offline   Reply With Quote
Old 2009-10-06, 02:54 PM   #10
truevis
truevis's Avatar
Originally Posted by mbalsom View Post
For those of us who don't have a "windows"key, how can I try this app...
It's very simple The lines in the AutoKotKey code that start things work like this: 1st line means only look for the hotkey if a certain window is active. The 2nd line is the hotkey -- in this case F5. ^=ctrl !=alt #=win key.
F5::  ; hotkey
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Speedy code cadprog VBA 3 2009-06-17 09:14 PM
CIVIL 3D 2010 OBJECT ENABLER FOR ARCHITECTURE 64BIT 2010 yangcheng2008 AutoCAD Civil 3D - Grading 1 2009-06-17 03:34 PM
Revit 2010 Doors and Windows are not cutting walls in Navisworks 2010 mike.massey NavisWorks - General 8 2009-06-05 09:30 PM
Revit 2010: BUG - Export to NWM 2010. World units problem sinzoff Русский - Revit 0 2009-05-22 12:26 PM
WOULD SPEEDY GONZALEZ USE REVIT? cybermole Revit - Platform 6 2008-01-25 07:24 PM
