Thursday, September 9, 2010
Go Back   AUGI Forums > AUGI Technical (English) > Programming > VBA/COM Interop
 Welcome, Guest.
Login
VBA/COM Interop Step inside and get the VBA help you have been looking for.
Reply
Thread Tools Display Modes
Old 2009-12-26, 05:44 AM   #1
kaenlorn
kaenlorn appears to be going the right way
Question Understanding the Bezier spline construction method
Hello!
This is my first time visiting this forum. I'm not sure that there are no solutions regarding my question... Please help me.
I've got the problem with understanding, how AutoCAD calculates the coordinates of spline key points. Everything I need just to know formulas. I don't understand, how the t-parameter can be calculated for an arbitrary point on the spline.
I'll be able to use them in my VBA project to examine my own algorithm of mesh building.
And how can I get a data about my spline in the model space in VBA?
Thanx for your attentiveness =)
kaenlorn is offline   Reply With Quote
Old 2009-12-27, 08:01 AM   #2
seant61
seant61 has a bright futureseant61 has a bright futureseant61 has a bright futureseant61 has a bright futureseant61 has a bright futureseant61 has a bright future
Default Re: Understanding the Bezier spline construction method
I’m not sure I understand the full scope of your question.
The one thing I can say with a fairly high degree of certainty is that VBA (as apposed to all the other available APIs) has the most restricted access to AutoCAD’s core curve libraries. This is not to say, however, that a programmer with the appropriate background could not recreate the functionality with the curve properties (ControlPoints/FitPoints, -Tangents, Weights, etc.) VBA does have available.
If, on the other hand, VB.NET (for instance) was the development language then a programmer would be able to tap into native AutoCAD libraries to further analyze curves for GetParameterAtPoint, GetFirst- and GetSecondDerivative, DistanceAtParameters or -Point, ClosestPointTo, etc.
seant61 is offline   Reply With Quote
Old 2009-12-27, 03:20 PM   #3
kaenlorn
Thank you, but I know that, and my question was about an algorithm of spline operation.
I use both VBA and VB.NET and would like to understand "the nature of AutoCAD splines". What are values of the t-parameter defined for each point?
I suppose that the first point of a spline should have t=0, the end point - t=1, and the i-point should have t=i/(n-1), where i=0..(n-1) - an index of the point, n - the number of points I want a spline is based on. Is this true?
Old 2009-12-27, 05:38 PM   #4
seant61
It is quite possible I’m still missing the critical point of the query, but:
AutoCAD can create both uniform and non-uniform (NURBS) splines. So, for instance, if a spline is created with the SPLINE command, the parametric range will be equal to the linear distance between all the selected Fit Points.
If, on the other hand, the spline is created via the Pedit - Spline then Spline – Object, the parametric range will be uniform, equal to the number of vertex – Degree. This uniform version is similar to joined Bezier segments. Each of the four segment able to be evaluated over a unit range 0 to 1, 1 to 2, 2 to 3, 3 to 4.
Run the LIST command on the two splines in the attached. Notice the differing parametric ranges for two, fairly similar, splines.
Old 2009-12-28, 02:15 AM   #5
kaenlorn
Oh! It's very helpfull, i've ever seen.
"The parametric range will be equal to the linear distance between all the selected Fit Points" - that's it! Thank you so much!
Now I can see how my mesh drawing algorithm works in formulas =)
I saw two points on your right drawing. They are not vertices needed to reconstruct a spline as I think. What are they for?
Old 2009-12-28, 07:00 AM   #6
seant61
Those are remnants of the Tangent vectors from the curve on the left.
With the drawing I uploaded to my previous post, try this:
Command: splinedit
Select spline: ***Select red spline created with Spline Command***
Enter an option [Fit data/Close/Move vertex/Refine/rEverse/Undo]: F
Enter a fit data option
[Add/Close/Delete/Move/Purge/Tangents/toLerance/eXit] <eXit>: P
Enter an option [Close/Move vertex/Refine/rEverse/Undo/eXit] <eXit>: X
Notice how that spline now only displays Control Points, and how those match the spline on the right.
Old 2009-12-28, 01:43 PM   #7
kaenlorn
Hmmm, it's the interesting toy =)
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
what is Bezier sherflor 3ds Max - General 2 2009-10-21 02:57 PM
Understanding Lookup bcole.200021 Dynamic Blocks - Technical 2 2009-04-06 10:05 PM
Create Bezier Surfaces in AutoCAD 2006 osw201 AutoCAD 3D (2006 or below) 3 2006-11-03 08:50 PM
not understanding sweeps harkeychad Revit Architecture - General 0 2005-05-27 02:02 PM
