Sonntag, September 5, 2010
Homepage   |   Suchen   |   Über AUGIde   |   Mein AUGI   |   Jetzt registrieren
Go Back   AUGI Forums > AUGI Technical (English) > AEC > Revit > Revit Architecture Support > Revit Architecture - General
 Welcome, Guest.
Login
Revit Architecture - General Main discussion area for the latest release of Revit Architecture.
Reply
Thread Tools Display Modes
Old 2010-01-07, 08:01 PM   #1
sthedens
sthedens's Avatar
sthedens is going the right waysthedens is going the right waysthedens is going the right waysthedens is going the right waysthedens is going the right way
Default Unselectable Elements
We have a project where some of the elements have become unselectable. We have tried both crossing and window selection methods. These happen to be casework family elements. Attached is a plan view of a window selection. In the image, the elements that are selectable and those that are not are in the same "Casework" workset. They cannot be selected in any view: plan, section, elevation, 3D... Any idea on what's wrong, how to correct it and/or how it happened in the first place?
sthedens is offline   Reply With Quote
Old 2010-01-07, 08:28 PM   #2
Scott Davis
Revit Technical Specialist - Autodesk
Scott Davis's Avatar
Scott Davis has become a constellationScott Davis has become a constellationScott Davis has become a constellationScott Davis has become a constellationScott Davis has become a constellationScott Davis has become a constellationScott Davis has become a constellationScott Davis has become a constellationScott Davis has become a constellationScott Davis has become a constellationScott Davis has become a constellation
Default Re: Unselectable Elements
are you using design options?
__________________
Scott D Davis
AEC Technical Specialist
Autodesk, Inc.
Want Revit Content? Use Seek!
http://seek.autodesk.com
Scott Davis is offline   Reply With Quote
Old 2010-01-07, 09:50 PM   #3
sthedens
sthedens's Avatar
You are correct sir!! I knew there was a reason I liked you Scott. We don't have design options for the project, but someone created them anyway.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Unselectable Objects irneb AutoCAD General 14 2009-11-03 11:05 PM
ok is unselectable in hatch Pat-North AutoCAD General 2 2009-04-17 12:41 PM
Unselectable viewports mbinde.106613 AutoCAD Civil 3D - General 3 2006-08-15 06:35 PM
Selecting the Unselectable! r.grandmaison AutoCAD Tips & Tricks 1 2006-05-06 12:44 AM
OLE object cannot be unselectable. jfujiwara AutoCAD General 1 2004-07-28 10:05 PM
