Thursday, September 9, 2010
Go Back   AUGI Forums > AUGI Technical (English) > Geospatial > AutoCAD Map 3D Support > AutoCAD Map 3D - General
 Welcome, Guest.
Login
AutoCAD Map 3D - General Ask your AutoCAD Map 3D 2009 or below questions here!
Reply
Thread Tools Display Modes
Old 2010-02-07, 10:35 AM   #1
ehgartner
ehgartner is infamous around these parts
Default shp import with attributes to text entities
hi,
I would need to import text labels from a shp file into autodesk map (2005/2006) text entities with attached object data. the text string and the object data comes from a shp attribute table.
this works great with import/shp, but I do get MTEXT entities, but I would need TEXT entities.
when exploding those mtext entities to text, the object data ia lost (set to default).
Is there any idea how i can do this automatically (maybe a lisp script or vba).
I spent about 2 days and was very surprised, that this could be so complicated.
another way would be to link the text to an external DB (MS Access) and then copy the values from the DB-fields to the obcect data table field. is this possible and how??
thanks for any help
ehgartner is offline   Reply With Quote
Old 2010-02-07, 01:23 PM   #2
Jmurphy
Geospatial Moderator
Jmurphy's Avatar
Jmurphy is shooting for the starsJmurphy is shooting for the starsJmurphy is shooting for the starsJmurphy is shooting for the starsJmurphy is shooting for the starsJmurphy is shooting for the starsJmurphy is shooting for the starsJmurphy is shooting for the starsJmurphy is shooting for the starsJmurphy is shooting for the starsJmurphy is shooting for the stars
Default Re: shp import with attributes to text entities
Is there a reason they need to be text objects instead of Mtext?
If you know lisp you can write a lisp to convert the mtext to text and copy the object data over.
Post a sample of what you need and you might get some help if you need it.
__________________
J. Murphy
AKA
Murph
The world is NOT flat so why is your GIS data?
http://map3d.wordpress.com/
Jmurphy is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Text entities not there..... Coolmo AutoCAD General 12 2008-05-07 01:13 PM
Extrusion Direction for text entities? ralphsanchez AutoCAD General 16 2007-04-27 05:43 PM
Blank text entities & remove them cadd4la AutoLISP 15 2005-12-22 12:45 AM
Improvements to text entities acadwishlist ACAD-001 (Archived) 0 2005-11-08 01:30 PM
Autocap feature available for all text entities acadwishlist ACAD-001 (Archived) 1 2005-10-31 03:24 PM
