Thursday, July 29, 2010
Go Back   AUGI Forums > AUGI Technical (English) > AEC > Revit > Revit in General > Revit - API
 Welcome, Guest.
Login
Revit - API The place where programming minded members can get together and brainstorm
Reply
Thread Tools Display Modes
Old 2010-02-10, 11:16 AM   #1
alexander.westrup
alexander.westrup is infamous around these parts
Default Get the visible lines from the projection plane
Hi all!
Im working on a project where i want to export all visible lines in a View3D view or a ViewSection. I have no problem finding the elements or to get every edge from them, but the problem is that those coordinates are in world coordinate system (3D) whereas i want mine in view coordinate system (x = right, y = up, z = towards view) as they are drawn on the projection plane / viewport on screen.
Do anybody know how this is done or where i can look to get more ideas?
Thx /Alex
alexander.westrup is offline   Reply With Quote
Old 2010-02-10, 02:32 PM   #2
joe.zhou
joe.zhou's Avatar
joe.zhou appears to be going the right way
Default Re: Get the visible lines from the projection plane
check Transform class in Revit API help document, plus ProjectLocation class if needed
joe.zhou is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
window above cut plane is visible. why? mfgarrod Revit Architecture - General 11 2009-12-11 02:15 PM
Symbolic lines: Cut vs Projection brent.130528 Revit Architecture - General 2 2009-08-20 04:49 PM
IAM/IPT Work plane/axis projection into IDW jgalinowski Inventor - General 3 2008-09-16 09:31 PM
Projection lines halftoned arabatzis Revit Architecture - General 4 2006-10-16 08:25 PM
Projection Plane Line styles Jshaver Revit Structure - General 1 2005-11-15 09:20 PM
