Oh yeah! It works great!
That's odd indeed. I can click any of the three and it fixes the session. It's the same issue expressed differently, yours is more annoying than mine I should think. Sounds like 64bit could be the issue. And yes, that arrow is discreet!!!!!!!!!!
For the record, my spec is:
Dell Precision T5500
Windows 7 64bit
Dual Quad core X5550 @ 2.67GHz
6GB RAM
NVIDIA Quadro FX1800 dv157.94
Dual Monitor
For the record, and comparison...
@Xi M Tower:
Asus P6T Mobo
Intel i7 960 (3.46 GHz Turboboost)
12 GB Patriot DDR3
Nvidia Quadro FX3800 - Driver 197.59
Windows 7 Professional 64 bit
Single Samsung monitor- but it's a 27" monster...
Impressive machine, but can you model a family such that it has a flexible angle in it when brought in to a project? I.E.: for a roof truss for a house or for a "ripped" 2 x member or for anything else that is not square where the angled side can rotate, pivot or stretch. I can achieve this in the family, but when brought into the project, it won't move. Any luck? or suggestions?
Tested as described above on one of my computers - no crashes. For me, everything works as it should.
EP6550 Duo Core 2.33 Ghz
4 GB DDR2 ram
ATI X1650 Raedon Video Card
Win7 64bit
HWA off or on same result
50MB Model size
I will test on the other one and report any crashes
Cheers,
Ian
Just tested after getting an e-mail asking about it...No issues at all...tried changing views and everything and no crashes.
Win 7 Ultimate 64bit
Intel Core2 Duo E8500 @ 3.16ghz
8 GB RAM
FX 1700 Vid Card 512MB
HWA: On....no issues...
Off....no issues
Michael "MP" Patrick
"I only drink :coffee: until it's acceptable to drink :beer: or :whiskey: or :wine:"
A gentleman at our office found a semi solution to the crashing when you select a material. Before you go into the replace command of the material, change the preview render quality to Draft Quality it should allow to continue without any errors. I have attached an image of what I am talking about.
See if this will fix your problem at this time.
I am been having similar issues with a file that I just upgraded from 2009 (upgraded to 2010 first and with an audit done before each upgrade). The file was upgraded for rendering purposes only, and I have had crashes in the material editor, 3D views and when printing a PDF!
I am wondering if people having problems with the material editor are working in upgaded files, or files that where started in 2011? Could this be the problem?
Regards,
Shaun Rudd
