Thread: Copy (Ctrl+C) Deselects Current Selection
    2005-03
    From Kerala, Currently located at Bangalore, India
    95
    Default Copy (Ctrl+C) Deselects Current Selection
    Hi All,
    I have a problem with AutoCAD.
    I selected some objects first. Then Applied the shortcut Ctrl+C to copy them to clipboard. But it deselects the current selection set and asking me to perform a fresh selection.
    I checked this variable;
    PICKFIRST - It is set to 1
    What could be wrong?
    2000-01
    Seattle WA USA
    5,859
    Default Re: Copy (Ctrl+C) Deselects Current Selection
    You failed to mention what version of AutoCAD you are using. Older versions of AutoCAD allowed you to change the behavior of Ctrl+C to match the even older way of canceling commands.
    TS15178
    R. Robert Bell
    Design Technology Manager
    Stantec
    2005-03
    95
    Oops... Sorry!!!
    I am using AutoCAD 2010...
    Earth
    9,805
    Quote Originally Posted by harilalmn View Post
    Hi All,
    Set QAFLAGS to 0.
    R.K. McSwain | CAD Panacea |
    2005-03
    95
    Hi rkmcswain....
    Thanks a lot... That worked...!!!
  1. Add to selection without holding ctrl option
    By Wish List System in forum Revit MEP - Wish List
    Last Post: 2012-07-04, 12:35 AM
  2. Replies: 0
    Last Post: 2011-10-11, 08:38 AM
  3. Previous selection deselects
    By jgregory in forum AutoCAD General
    Last Post: 2009-01-30, 05:54 PM
  4. Selection Cycle using CTRL key in AutoCAD LT 2007, is it possible
    By James.Head in forum AutoCAD LT - General
    Last Post: 2007-01-10, 09:23 AM
  5. Can't copy or paste (Ctrl+C & Ctrl+V) from a drawing file
    By katkinson0082914 in forum AutoCAD General
    Last Post: 2006-08-14, 04:30 PM
