Thread: How select & Move Parts into new Assly!
    2002-10
    236
    Cool How select & Move Parts into new Assly!
    HI! Is there a way to select a group of separate parts that are in an assembly & move them into there own assembly! The only option I have is "Demote" & this allows me only to move one part at a time into its own assly! I cant move the rest of the parts into that assl'y. Inventor just wants to keep creating new assl'ys for each part! Any ideas! Using Inventor 2011.
    Thanks!
    Paul
    Active Member chadwickt's Avatar
    2015-12
    84
    Default Re: How select & Move Parts into new Assly!
    Hi Paul,
    After demoting the first part (and thus creating a new subassembly), double-click on the new subassembly to make it current. You can then drag the other parts into the subassembly.
    2006-05
    Jonesboro, AR
    4
    Thanks for the info.
    2015-12
    84
    Thumbs up Re: How select & Move Parts into new Assly!
    I hope that helped!
    Williamsport, PA
    641
    Quote Originally Posted by Cosmic Traveller View Post
    Paul
    You can Demote as many parts and sub-assemblies as you like at one time into a new sub assembly.
    Simply Ctrl click to select them and then right mouse button Component>Demote.
  1. Select and move a block
    By eugeniocunha in forum Dot Net API
    Last Post: 2011-11-09, 02:09 PM
  2. 3D move parts quickly but accurately
    By FProcp in forum Inventor Wish List
    Last Post: 2011-09-30, 02:28 PM
  3. 2011: Select then Move
    By BeKirra in forum AutoCAD General
    Last Post: 2010-11-30, 03:39 AM
  4. Select parts for Breakout View
    Last Post: 2010-09-16, 03:49 PM
  5. Using a Crossing Window to Select Multiple Parts to Pattern
    Last Post: 2006-06-02, 03:09 AM
