Thread: Zone Based Clashing
    Wish List Administration
    2011-08
    4,581
    Default Zone Based Clashing
    Summary: Functionality that allows the user to create clash tests confined to a 3 dimensional zone within the building based on a selected mass object of any shape.
    Description: I propose functionality that allows the user to create clash tests by a 3 dimensional zone within the building.
    Benefits
    This would allow the user to clash specific irregular shaped areas of the building that would more closely follow the construction sequence and schedule within areas (or zones). This could also eliminate having to break up subcontractor files into smaller files so that these specific area can be clashed.
    How would it work?
    The user could create the construction zones of any shape in the Revit model as generic masses. These masses would be recognized by Navisworks as an optional clash test filter or rule.
    Assemble your Navis model by appending entire buildings or entire building levels as appropriate. Set up your clash tests as you normally would (mech vs. elec, mech vs. plumbing, etc) for an entire level, then select the Mass object representing the zone as a filter/rule condition.
    Because all clashes have an X,Y,Z value, use that selected mass as part of a rule “I only want to see clashes that exist within the volume of the selected mass”. Or to more closely follow the “Rules” tab, “Ignore all clashes outside of selected Zone Mass”.
    This feature would save us and our subcontractors countless hours of breaking up some of the files because we need to clash a specific area that follows the construction sequence and is not a rectangular shape like a section box. This time savings would be multiplied as subs correct their design and have to break up their updated files and send us updates.
    Product and Feature: Navisworks Manage - Clash Detective
    Submitted By: Daron Denton on Fri, 18 May 2012
    2011-08
    4,581
    Exclamation Re: Zone Based Clashing
    Zone Based Clashing
    Benefits
    How would it work?
    2011-08
    4,581
    Zone Based Clashing
    Benefits
    How would it work?
    2011-08
    4,581
    Zone Based Clashing
    Benefits
    How would it work?
  1. Separate colors for clashing objects
    By dgorsman in forum NavisWorks - Wish List
    Last Post: 2011-08-25, 06:47 PM
  2. CAD Files clashing with each face
    By art.theusch in forum NavisWorks - General
    Last Post: 2010-04-09, 07:53 PM
  3. Selective Clashing
    By mortenson.eric in forum NavisWorks - General
    Last Post: 2009-06-11, 04:18 PM
  4. zone de masquage / zone remplie
    By a.unam in forum Revit Architecture - General
    Last Post: 2008-06-20, 04:05 PM
