Thread: missing pen settings - plotting
    2003-04
    17
    Lightbulb missing pen settings - plotting
    One of the computers in the office is having problems with the pen settings. We have already loaded all the pen settings on ADT 2005 (enu) and at the c: drive, and it still can't not plot with any pen settings. Any suggestions? At the plot dialog box, plot style table (pen assignments) has no options at all. It is not even showing the basic pen settings that AutoCAD has: w&b, monochrome, ........;
    This computer is running on Windows 2000, not XP, is this affecting?
    Please help.
    Thanks
    Ana
    Moderator arcadia_x27's Avatar
    2015-10
    The 'Mill,Moncton, NB, Canada
    516
    Default Re: missing pen settings - plotting
    Just a thought, Are your penstyles located in the same folder on your 2000 machine as they are in XP because if I'm not mistaken they're located in a different location on a 2000 machine than on an XP one.
    2004-12
    34
    Two things come to mind:
    1. I agree with Arcadia, make sure that in your profile, your plotter is looking in the correct directory.
    2. The thing I run into most of the time is if your drawing is setup to plot by Color and the drawing was created to plot by Style, it could cause an issue. Solution for this is at the command prompt, type in 'convertpstyles'. That will change from .stb to .ctb.
    Hope this helps...
    Administrator richard.binning's Avatar
    2015-12
    In the foothills of the appalachians
    2,261
    Quote Originally Posted by ana.50715
    Please help.
    Thanks
    Ana
    So does your PlotStyleTables Selection box look like the following?
    Chances are that AutoCAD is pointing to the wrong folder. Download the attached lisp file and drag it onto your AutoCAD window. When you run the attached routine does it result in an empty folder like this graphic?
    Take a look in the folder that pops up. If it is empty like the second screen shot above then you have found your problem. Just visit your options dialog box and browse to the correct folder.
    Hope that helps,
    RLB
    2003-04
    17
    Thanks for the reply.
    I run the routine. And it was already a ctb file.
    But when I went to the options dialog box, under plot and publish tab, plot and style table settings, and try to add or edit the plot styles tables - I got the following message: does not exit or is not in a folder.
    Where should I control the path for the plot settings on these machine, and which path, should I direct to the one above ........application data, autodesk, enu, plot styles?
    Thanks
    Ana
  1. 2014: Missing custom render settings
    By matt__w in forum Revit - Rendering
    Last Post: 2015-04-21, 03:44 PM
  2. 2012: Missing SHX file when plotting
    By Noto81 in forum AutoCAD General
    Last Post: 2012-11-26, 10:12 PM
  3. Document Settings Drawing Tab Missing...
    By whf in forum Inventor - General
    Last Post: 2012-10-29, 12:51 AM
  4. Missing linework when plotting to PDF
    By crl_arch in forum AutoCAD General
    Last Post: 2009-11-06, 11:39 PM
  5. Missing Viewports when Plotting & Previewing
    By BeKirra in forum AutoCAD Plotting
    Last Post: 2006-10-12, 10:27 PM
