Thread: -MAPINSERTPLE command for Dynamic Scale Bar
    2006-03
    San Cristobal, Guatemal
    439
    Default -MAPINSERTPLE command for Dynamic Scale Bar
    Pardon my ignorance, could someone assist with what to do next after -MAPINSERTPLE has been entered? The command line is asking for a block name, what and where do I find this block?
    Cairo - no, not Illinois
    5,070
    Default Re: -MAPINSERTPLE command for Dynamic Scale Bar
    The sample drawings in C:\Program Files\Autodesk\Autodesk AutoCAD Civil 3D 2014\Sample\Symbols\; "Map - Scale Bars.dwg" and "Map - North Arrows.dwg" are apparently hardwired into the ribbon interface for that command. I simply copied and modified one of the existing dynamic blocks in there to look like my company standard north arrow, and it works.
    I haven't bothered playing with bar scales -- the corporate standard is a dynamic block already, and I don't see a need to tweark it.
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,686
    Quote Originally Posted by Darren Allen View Post
    See https://www.theswamp.org/index.php?t...0904#msg610904
    https://forums.autodesk.com/t5/civil...9970125#M19256
    and http://www.theswamp.org/index.php?topic=48049.0;all.
    2001-03
    Tallahassee, FL USA
    3,686
    I've added drop-downs for custom North Arrows I created described at this link: https://beauford.altervista.org/Dynamic_Blocks.html
    The macro example
    ^C^C^P(progn(startapp "explorer" (strcat "/n,/e," (vl-string-subst (strcat "Map" (chr 92) "Sample" (chr 92) "Symbols") "express" (vl-filename-directory (findfile "acetauto.lsp")))))(princ));
    should open the folder the read only Blocks.dwg is in.
    I recreated all the blocks to use Mtext with use drawing background color set to Fill color so it's readable over aerials using Standard as the Text Style overriding the fonts in the editor so they display correctly without adding extra Text Styles when they're inserted. You can download it from https://www.theswamp.org/index.php?t...0904#msg610904
  1. Field for Dynamic Viewport Scale
    By BThiele in forum AutoCAD Fields
    Last Post: 2014-02-04, 02:14 PM
  2. USE MOVE,COPY,ROTATE,SCALE COMMAND IN ONE COMMAND
    By cadsoft in forum AutoCAD Tips & Tricks
    Last Post: 2011-03-14, 02:47 PM
  3. Dynamic Block Linetype Scale
    By scoutmaster in forum Dynamic Blocks - Technical
    Last Post: 2008-12-22, 09:00 PM
  4. Help to Get X scale Value of a Dynamic Block
    By CADdancer in forum AutoLISP
    Last Post: 2008-03-17, 03:31 PM
  5. Hatch with dynamic scale
    Last Post: 2006-01-30, 10:20 PM
