Results 1 to 10 of 15
Thread: Scaled Titleblocks
    2013-09
    Houston, TX
    11
    Default Scaled Titleblocks
    Ever since I started working in AutoCAD I have kept Paperspace at 1:1 and cut a Viewport to the needed drawing scale. Unfortunately I am working with a 3rd party software that cuts my sheets, where the viewport is 1:1 and the Title Block is scaled to the drawing scale. My problem then comes into effect of when I try to use Civil Object Layers.
    Is there a universal setting so that I can turn off the dependence on Viewport Scale? Or override the Annotation Scale to be different from the Viewport Scale?
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,686
    Default Re: Scaled Titleblocks
    What 3rd party software is it? You may want to contact them about this. What you're describing kind of defeats the purpose of having Paperspace.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,196
    Why not create your own viewport in paperspace showing the entire titleblock, which your 3rd party software is generating? There is nothing that says you have to place your titleblock in paperspace, other than it makes more sense to be located there.
    2013-09
    Houston, TX
    11
    The program is called Blue Sky or Skyline. The Titleblocks are not in Model Space, I work in real world coordinates so the view is moved and twisted for each sheet, that part of Paperspace is utilized. My best guess is that for programming purposes it is easier for the sheet layout and annotated with the titleblock at 1:1. It has been mentioned to the company, but the software isn't tied to use with Civil 3D.
    2009-11
    5,780
    You haven't tried using an attributed Title Block, populated with fields that reference SSM properties, have you?
    Cheers
    Computer Specs:
    Dell Precision 5860, Xeon W7-2495X, 128GB RAM, Dual PCIe 4.0 M.2 SSD (RAID 0), 20GB NVIDIA RTX 4000 ADA
    2009-11
    5,780
    Quote Originally Posted by SA Ross622 View Post
    Forgive the question, as I am not familiar with the products you mention, but how is this any different than Civil 3D's built-in Plan Production Tools - you know, aside from the 3rd party apps scaling your paperspace components so that Viewport is 1:1, potentially breaking all annotative scales, etc.?
    Cheers
    Computer Specs:
    2013-09
    Houston, TX
    11
    The Titleblock is fully annotated. The annotation I am talking about is dimensions, callouts and misc linework that describes changes in pipe material.
    Here is an image of an Alignment sheet. Basically all the info on the sheet outside the viewport is generated by the software.asm.gif
    2001-03
    Tallahassee, FL USA
    3,686
    Cannot make out much in that image, like BlackBox wondering what that software does that couldn't be done without it or the problems it's causing.
    Sometimes less is more…
    2013-09
    Houston, TX
    11
    I need to change how Civil 3D displays its labels, if that is not possible I will be forced to create the Civil Callouts to scale and explode them before going into Paperspace to plot the drawings. This negates having the advantage of automating the callouts, and then I should not waste my time and make it mtext and dtext.
    I don't have the abilty to change the 3rd party software, I can not change what information or how its located on the sheet. I am looking for a setting that will allow me to display Civil 3D labels in modelspace without going through all the drawing settings and scaling them up to a size that works.
    2009-11
    5,780
    Civil 3D is dependent on Annotation Scales - a paperspace Viewport has two Scales, Annotative, and Standard (aka zoom).
    There is a one-way relationship between these Viewport Scales; when one changes the Annotation Scale, the Standard Scale is automagically changed in kind. When one changes the Standard Scale, the Annotation Scale remains the same.
    It sounds to me, like you have a Viewport Scale mismatch that is affecting the resultant sheet output, and that is a 3rd party software caused problem - You'd be lucky if this is merely a supplementary step after-the-fact, to manually change the Annotation Scale to match.
    Cheers
    Computer Specs:
  1. How to jig scaled Multiviewblockreference
    By AntonAlalaev in forum Dot Net API
    Last Post: 2014-04-30, 02:49 PM
  2. Can a tRevit Top Surface be scaled??
    By jseltzer in forum Revit Architecture - General
    Last Post: 2010-01-26, 04:14 PM
  3. Why does a CAD survey ALWAYS come in scaled??
    Last Post: 2009-04-08, 08:12 PM
  4. Inserts scaled wrong
    By scottsmith in forum AutoCAD General
    Last Post: 2005-11-03, 10:23 PM
  5. Scaled dwgs
    By Ed Jobe in forum New Forum Users (Non technical)
    Last Post: 2004-09-27, 04:40 PM
