Results 1 to 10 of 14
Thread: Command, vl-cmdf and command-s Autocad 2015
    2009-03
    39
    Default Command, vl-cmdf and command-s Autocad 2015
    Hi,
    If ListPoints is a list of points and R is a distance,
    with Autocad2015:
    Case 1:
    (mapcar '(lambda (pt) (command "_circle" pr R)) ListPoints)
    returns: VVC: Internal Error
    Case 2:
    (mapcar '(lambda (pt) (vl-cmdf "_circle" pr R)) ListPoints)
    Case 3:
    (mapcar '(lambda (pt) (command-s "_circle" pr R)) ListPoints)
    Works Ok.
    With Autocad2013 case 1 and case 2 work Ok. Why not now?
    Command-s can avoid problems, but... if the order was:
    (mapcar '(lambda (pt) (vl-cmdf "_pline" pt)) ListPoints)
    command-s doesn't generate a single pline.
    2009-11
    5,780
    Default Re: Command, vl-cmdf and command-s Autocad 2015
    Kean's AutoCAD 2015: calling commands article may be able to provide some clarification... Put simply the ObjectARX functions were modified, which LISP is ultimately dependent on, and despite Autodesk generally handling which new 'correct' ARX call to make in the LispFunction code-behind, without changing the calling LISP, there are instances where Command-s is needed as you're already aware.
    Cheers
    Computer Specs:
    Dell Precision 5860, Xeon W7-2495X, 128GB RAM, Dual PCIe 4.0 M.2 SSD (RAID 0), 20GB NVIDIA RTX 4000 ADA
    2009-11
    5,780
    Also, FWIW -
    (vl-load-com)
    (defun _MakeCircles (doc points radius / oSpace circles)
      (setq oSpace (vlax-get doc
                             (if (= 1 (getvar 'cvport))
                               'paperspace
                               'modelspace
      (foreach pt points
        (setq circles
               (cons (vla-addcircle oSpace (vlax-3d-point pt) radius)
                     circles
      (reverse circles)
    Computer Specs:
    2010-06
    962
    To work with entmake(x) is much better than the use of command calls specially in lisps .
    (mapcar '(lambda (pt) (entmake (list '(0 . "CIRCLE") (cons 10 pt) (cons 40 R)))) ListPoints)
    2009-03
    39
    Thank you, Tharwat, I will use your idea. I love plain Lisp.
    But the main question is not how to draw circles but why suddenly command, vl-cmdf don't work. I have lot of codes, and I have never hadd problems with new autocad versions, i don't understand why now.
    By the way, how can I solve the problema with the pline?
    2009-11
    5,780
    Quote Originally Posted by l3ch View Post
    I love plain Lisp.
    I opt for Visual LISP for ease of supporting UNDO functionality, which 'plain LISP' can only accomplish with Command calls, or to use Visual LISP for the UNDO portion, in which case you'd just use same in the first place. Also, with any 'current' workstation, 'plain LISP' doesn't have any real, demonstrable difference in performance for end user, as is not as 'plain' to read (DXF has always been cheeky that way).
    Please read Kean's article, linked above.
    (vl-load-com)
    (defun _AddPolyline (doc points)
      ;; Example: (_AddPolyline acDoc listPoints)
      (if (= (rem (length (setq points (apply 'append points))) 3) 0)
        (vla-addpolyline
          (vlax-get doc
                      'paperspace
                      'modelspace
          (vlax-safearray-fill
            (vlax-make-safearray
              vlax-vbDouble
              (cons 0 (- (length points) 1))
            points
    Cheers
    Computer Specs:
    Past Vice President / AUGI Volunteer peter's Avatar
    2000-09
    Honolulu HI
    1,139
    I noticed in your lambda expression(at the top) you have the argument (pt) but in the expression you have a variable pr
    This is what I see above.
    Try
    (mapcar '(lambda (pt) (vl-cmdf "_circle" PT R)) ListPoints)
    Worked for me.
    P=
    AutomateCAD
    2009-03
    39
    Thanks, Peter, it was a misprint. I thought everybody caught the idea and I didn't want to add another message with the correction. I apologize for any inconveniences.
    2009-03
    39
    Thanks, BlackBox. Kean'sarticle was hard for me, but I get the idea. Is a matter of fact, Autocad2015.
    Thanks again for your code with the pline solution.
    I have rewritten my codes, where I used (mapcar '(lambda... with lots of commands and so, I have created small subroutines (like _AddPolyline).
    2009-11
    5,780
    You're welcome, l3ch; reading Kean's (and others') articles gets easier the more you understand.
    As Peter aptly demonstrated, there's nothing wrong with the Command version either. To my mind it's more about using the right method for any given task, so as a small example, you could not use the command option in a ObjectDBX batch process, whereas you could use my offering, but you're unlikely to perform a batch process often.
    Hope this makes (more?) sense.
    Cheers
    Computer Specs:
  1. 2007: Publish Command says unknown command in autocad 2007
    By drajappa594109 in forum AutoCAD General
    Last Post: 2012-07-13, 03:34 PM
  2. Replies: 6
    Last Post: 2007-04-23, 01:40 AM
  3. AutoCAD LT 2007 Appload command returns - unknown command
    By tbedrich in forum AutoCAD LT - General
    Last Post: 2007-04-10, 02:09 PM
  4. Replies: 4
    Last Post: 2006-05-09, 08:57 PM
  5. Replies: 8
    Last Post: 2005-06-30, 02:32 PM
