Results 1 to 10 of 10
Thread: pipe styles keep changing
    2015-12
    Default pipe styles keep changing
    hello
    has anyone using 2015 civil 3d had any problems with the pipe style changing back to standard after you synchronize the pipe network? i have a drawing that has a data shortcut and when i open the drawing or synchronize it will change back to standard style. it is very frustrating, any ideas on how to fix it?
    2009-11
    5,780
    Default Re: pipe styles keep changing
    Ohh bother, I've kept Alan waiting entirely too long for this - thanks for the reminder, J_Gardella.
    http://www.theswamp.org/index.php?topic=45446.0
    Cheers
    [Edit] - Just consolidating links for reference later; For those not already familiar with Civil 3D's Data Shortcuts workflow....
    http://forums.augi.com/showthread.ph...older-Location
    Computer Specs:
    Dell Precision 5860, Xeon W7-2495X, 128GB RAM, Dual PCIe 4.0 M.2 SSD (RAID 0), 20GB NVIDIA RTX 4000 ADA
    Earth
    9,831
    Quote Originally Posted by J_Gardella View Post
    hello
    Install SP3. It includes the fix, which is actually in SP1.
    R.K. McSwain | CAD Panacea |
    2009-11
    5,780
    Thank you, RK; as always.
    Looking back, our other thread started back in 2013, and Alan was(is?) using 2013, even after reviving the thread in early 2015. Haha
    Cheers
    Computer Specs:
    Earth
    9,831
    Quote Originally Posted by BlackBox View Post
    Looking back, our other thread started back in 2013, and Alan was(is?) using 2013, even after reviving the thread in early 2015....
    I recall when this started happening. The only workaround was to close the DWG w/o syncing, then open the DWG again.
    What a waste of time.
    2009-11
    5,780
    What allowed me to forget about this altogether was I simply changed our workflow; pipes were drawn in our Profile model drawing, so no DREF needed (we don't use PPT; just XREF the Profile model).
    Computer Specs:
    Earth
    9,831
    Our profile drawings are usually a separate, empty DWG, with the alignment, surface(s), and pipe network(s) d-ref'ed in.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,196
    Are you then referencing this profile drawing into your plan and profile sheet drawing? Does this speed up your load times?
    Earth
    9,831
    Yes, and I'm not sure.
    It does provide two more advantages (for us at least).
    1. Multiple drawings allow multiple people to work on them simultaneously.
    2. A corrupt or damaged DWG file containing one profile is better than a corrupt or damaged DWG containing all the profiles for a project.
    100 Club Openwheeler's Avatar
    2006-11
    Heartland of the Mid-west, home of the Indy 500
    163
    Yeah, that sucked back then!
  1. 2014: Changing the size of pipe-up and pipe-down symbols?
    By susanne.brown499436 in forum Revit MEP - General
    Last Post: 2014-08-05, 05:21 PM
  2. Changing Styles on the Fly
    By CADKid in forum ACA General
    Last Post: 2010-05-12, 01:11 PM
  3. Changing from CTB to Plot Styles
    By GreyHippo in forum CAD Management - General
    Last Post: 2010-02-16, 01:32 AM
  4. Changing Plot Styles
    By Rico in forum AutoCAD General
    Last Post: 2008-01-08, 08:43 PM
  5. Changing dim styles of a selection set
    By ewuensch in forum AutoLISP
    Last Post: 2007-01-10, 01:00 PM
