Thread: Get Attributes Without Opening Drawing Files
    2015-09
    420
    Question Get Attributes Without Opening Drawing Files
    Good Afternoon AUGI Members:
    I am relatively new to VBA programming and I do not know if this question was already posted, so I apologize in advance if it has been asked before.
    I would like to have a VBA routine allow the user the ability to select a directory of AutoCAD drawing files (batch) and extract known attributes from these files and then write this information into an Excel spread sheet. From what I have read so far it appears that this can be accomplished but I do not know where to start or how to begin. If someone can point me in the right direction and or provide some simple examples for me to get started I can attempt to develop this routine.
    I would appreciate any assistance with this effort.
    Regards,
    Vince
    2000-01
    Seattle WA USA
    5,859
    Default Re: Get Attributes Without Opening Drawing Files
    Vince,
    The mechanism you are looking for the the ObjectDBX interface. It permits access to drawings without opening them visibly in the editor. (So they open much faster.)
    'Requires reference to AutoCAD/ObjectDBX Common Type Library
    Option Explicit
    Sub Test()
      Dim oDBX As AxDbDocument
      Set oDBX = New AxDbDocument
      oDBX.Open "C:\Temp\Test.dwg"
      MsgBox "First layer name is " & oDBX.Layers.Item(0).Name
      Set oDBX = Nothing
    End Sub
    Turlock, CA
    6,584
    As for the other parts, connecting to other programs like xl is called ActiveX automation. If you installed the samples with acad, there is one on extracting atts to xl.
    C:> ED WORKING....
    LinkedIn
  1. Replies: 2
    Last Post: 2007-06-12, 11:23 AM
  2. Replies: 12
    Last Post: 2007-06-12, 08:55 AM
  3. Wipeout Proxy Objects when opening drawing files.
    By LynNV in forum AutoCAD General
    Last Post: 2006-07-18, 05:50 PM
  4. Opening Drawing files from commandline...
    By Chris Matira in forum AutoCAD General
    Last Post: 2005-12-07, 08:22 AM
  5. Remove Read Only attributes from drawing files
    By eng5 in forum AutoCAD General
    Last Post: 2005-05-03, 12:44 PM
