Results 1 to 1 of 1
Thread: Hatch patterns playing you up
    13,657
    Default Hatch patterns playing you up
    Experiencing issues / problems with Hatch patterns ie
    Hatch pattern displays broken up.
    Spacing too dense or hatch pattern too small.
    Hatch pattern not displaying.
    Hatch pattern origin in wrong location.
    Gradient Hatch pattern not displaying as you wish.
    etc.
    The below information might just help resolve such issues / problems....
    Links:
    Autodesk Knowledge Base:
    ID: TS60223 - Hatch patterns display incomplete or broken up
    ID: TS32120 - Starting point of hatch is in wrong location
    ID: TS17458 - Use MaxHatch system variable to control hatch density
    ID: TS76597 - Error: EHatchTooDense
    ID: TS82277 - Unable to drag associative hatch or gradient to tool palette
    ID: TS81672 - Gradient fill plots with bounding box
    ID: TS40955 - Hatch patterns not visible when working in drawings from earlier releases
    ID: TS67839 - Settings that control printing of filled text and solid hatches
    AUGI Forum:
    Concrete Hatching problems
    Using a Spline as a Hatch boundary?
    Move Hatch Pattern Origin
    User defined hatch problem
    Hatch problem
    Fix "Broken", Random Looking Hatch Patterns
    BHatch
    hatch patterns gone goofy
    hatch problem
    AutoCAD LT 2005 - Hatch issues
    Hiding Hatch patterns.
    Solid Hatch not displaying
    Gradient Hatching @ angles
    Gradient hatching a lake
    Hatch Pattern density
    Exploded-looking AR-CONC hatch pattern?
    hatch pattern problem
    different hatch pattern table
    Hatch pattern becomes "scrambled"
    Same old Hatch problems... Valid hatch boundary cannot be found...
    Why does my hatch not draw as it is displayed?
    Hatch pattern with a mind of its own!
    Gravel hatch is all broken up
    Hatch does not show up in drawing
    Hatch Pattern Too Dense
    Finding break in hatch boudary
    Error: Hatch spacing too dense or hatch size too small
    Same Hatch pattern, same scale, displays differently in two separate DWG files
    Hatch scale/angles different per computer
    All of a sudden some of my hatches are displaying incorrectly - broken up
  1. 2015: create/ convert hatch patterns (.pat) to revit fill patterns
    By jledgewood in forum Revit Architecture - Tips & Tricks
    Last Post: 2015-06-01, 11:48 PM
  2. Floor Patterns not playing by the rules?
    By amador.210449 in forum Revit Architecture - General
    Last Post: 2011-10-21, 03:05 AM
  3. Replies: 5
    Last Post: 2008-03-16, 07:00 AM
  4. Hatch Patterns
    By Mr Cory in forum AutoCAD General
    Last Post: 2007-09-28, 02:26 AM
  5. Hatch Patterns
    By whittendesigns in forum Revit Architecture - General
    Last Post: 2007-01-26, 04:10 PM
