Results 1 to 6 of 6
Thread: Select a Field in MText and have it highlight the object it is representing?
    2004-06
    Slidell, Louisiana
    993
    Question Select a Field in MText and have it highlight the object it is representing?
    when using a field to display an area of a hatch or closed polyline, is there a way to select or highlight the field
    in the mtext and have it display/highlight/zoom to the object it is representing?
    Turlock, CA
    6,564
    2
    Default Re: Select a Field in MText and have it highlight the object it is representing?
    Not OOTB. You might be able to do it with code.
    C:> ED WORKING....
    LinkedIn
    2004-06
    Slidell, Louisiana
    993
    thanks Ed. appreciate the info. i was so hoping it would
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,686
    3
    2004-06
    Slidell, Louisiana
    993
    thanks Tom. Going to use Lee Mac's routine. totally forgot about him. have used many of his routines in the past.
    2001-03
    Tallahassee, FL USA
    3,686
    Quote Originally Posted by rmk View Post
    That's the one I use as well, here's the macro I use:
    Command Name: Field→Objects
    Description: Display links between Fields & Objects.
    Macro:
    ^C^C^P(or C:FieldObjects (load "FieldObjectsV1-0.lsp"));FieldObjects
    Small image: RCDATA_16_INSERT_FIELD
    Large image: RCDATA_32_INSERT_FIELD
    I'm also a heavy user of Lee Mac's routines as well, I have over a dozen macros using his "Steal from Drawing" routine alone. It's my all time favorite download!
  1. Creating an MText object with a field
    By Jim_Fisher in forum AutoLISP
    Last Post: 2016-10-24, 01:56 PM
  2. select object then have area in field
    By ignjat123 in forum AutoCAD Fields
    Last Post: 2009-12-17, 08:09 AM
  3. Highlight Selected Object During the Area - Add - Object Command
    Last Post: 2007-05-26, 06:12 PM
  4. Highlight Object, right click, select Properties causes Fatal Error
    By jlbuilder117922 in forum AutoCAD General
    Last Post: 2006-07-30, 06:38 AM
  5. Field editor to highlight selected object
    Last Post: 2006-06-07, 01:52 PM
