anyone have any tutorials on using the pipes pulldown
A little more information might help you get what you're looking for, like:
What version of AutoCAD are you working with?
What is it you are trying to do with the pipes?
If you're just looking for general tutorials, give the AutoCAD help menu a try. I've found some pretty good information there.
In LDT 2005,
Give this menu a try: Help > Getting Started Guides > Civil Design Getting Started
What will come up is a PDF that has 8 chapters. Chapter 7 deals with Designing Pipe Runs
Also, try this menu: Help > Autodesk Land Desktop Help (F1)
If you type in "pipes" in the search box, you'll get a list of items that might help you out.
Unfortunately, there isn't a whole lot more I can give you.
Hope it helped, have a good one.....
RW
We are working with LDT2004 and i tried the help file and there wasn't much in there.
I'm not sure how different 2004 is from 2005 when it comes to pipes, but from what I understand, they are almost identical in just about every other aspect. Give this PDF a look over, it might help, it might not.
The only real difference between 04 & 05 is more stability with 05, both work very well.Originally Posted by RobertW.82344
So the documentation that I provided should be the same for 04 & 05?
I thought they put curved pipes in the 05 version? didn't it make it into that release? If they did, that would be the only change between the two that I am aware of.
