Thread: Apply same visibility graphics of one Revit link to other Revit links
    2019-06
    2
    Question Apply same visibility graphics of one Revit link to other Revit links
    I have MEP view templates applied to my MEP floor plan views that control the properties of all but 'V/G Overrides RVT Links'. I have a separate view template that I "apply template properties" on each floor plan view which controls only the properties of 'V/G Overrides RVT Links'.
    This works great for a single linked model (structural). But then when I add another link (architectural), I have to go in and set all of the VG overrides the same exact way for that model.
    Is there any way to avoid these extra steps of setting the VG settings for every single link?
    2015-11
    Saint Louis, MO
    486
    Default Re: Apply same visibility graphics of one Revit link to other Revit links
    Not that i know of. In our project template, i have created and linked in ghost revit files for arch, structure, m, e, p, furniture, shell arch, that i went thru and set v/g for in all of my view templates. After a project is started, we then pick the arch link from manage links, and Reload From, browse to where the new project arch file is saved, and all of the linked file v/g will remain set in your view templates. Then do the same for struc, and whatever other models you have. it sounds like a big effort up front, but well worth it from job to job. They're not perfect, i'll have to adjust something here and there with different architects and structural firms, but it's a really good start. And if i remember, i'll go add the various changes/filters (hide an egress path line, etc.) to the main template so the next model we get from a particular architect is already set correctly.
    hth,
    mike
    2017-07
    Virginia Beach, VA
    9
    I do something similar to @mhartmann. My template is an .rvt file with worksets and ghost link models loaded in. I then created my view templates based on how i want my coordination, analysis, and sheet views to display down to the smallest detail. At the start of every project, i copy over this .rvt file, rename it, create a central and then bring in my links by using "Reload From...".
    Hope this helps...
    BJ, The BIM Guy
    2016-05
    5
    Is there any way to avoid these extra steps of setting the VG settings for every single link?[/QUOTE]
    Use "View templates"
    In the view already set do: create view template from current view, then apply it to the new view.
  1. Find Takeoff in other Sheet and Models by using links and/or graphics
    By Wish List System in forum NavisWorks - Wish List
    Last Post: 2017-03-16, 01:36 PM
  2. 2013: Room Tags and Annotation Crop; Visibility Graphics for Revit Links
    By greyghost1984 in forum Revit Architecture - General
    Last Post: 2012-10-26, 07:06 AM
  3. Replies: 0
    Last Post: 2007-05-09, 07:09 PM
  4. Link Attachment vs Overlay? (links within links)
    By kurk in forum Revit Architecture - General
    Last Post: 2006-07-27, 04:24 AM
Tags for this Thread
