Thread: Search various folders drawings (.dwg files) for a specific block name.
    2010-01
    8
    Default ---------------------------------------------------
    2009-11
    5,771
    Default Re: Search various folders drawings (.dwg files) for a specific block name.
    Have you tried using Design Center (ADCENTER Command), then simply click the Search button?
    In the Search dialog, filter for Blocks and enter the Block Name you want to look for, then you can populate your spreadsheet, no?
    Computer Specs:
    Dell Precision 5860, Xeon W7-2495X, 128GB RAM, Dual PCIe 4.0 M.2 SSD (RAID 0), 20GB NVIDIA RTX 4000 ADA
    Active Member dotson's Avatar
    2005-01
    56
    You might want to try the DwgSearrch Freeware from the Autodesk App Store ...
    https://apps.autodesk.com/ACD/en/Det...en&os=Win32_64
    Simply check on the Block toggle in the tables section. When the results are complete click the [Copy to Clipboard] button and paste it into Excel or any other application. The DwgSearch is fast because it doesn't actually open the drawings in the editor.
    2
    with lisp you can use getstring to specify a block name, acet-ui-pickdir to select a folder, ObjectDBX/vla-get-blocks to go inside a drawing database and then write the search results to a csv file
  1. Replies: 1
    Last Post: 2017-01-15, 12:22 AM
  2. Replies: 0
    Last Post: 2012-02-08, 03:23 PM
  3. Replies: 5
    Last Post: 2009-04-17, 10:10 AM
  4. Can I search for a specific block name?
    By pmedina in forum AutoLISP
    Last Post: 2009-02-24, 12:47 PM
  5. memorize various furniture positions in various phases
    By gravelin in forum Revit Architecture - Wish List
    Last Post: 2005-08-01, 09:30 PM
