Thread: Corridor section shows odd green box
    2017-09
    71
    Default Corridor section shows odd green box
    We have done about 5 jobs using corridors to design road widening and then do cross sections in Civil 3d. We have the latest job that is generally working well but on one section only some odd green box came up. It is tied to the corridor some how but I can't figure out why it is there. The section is using it for sizing too, which it shouldn't. I cannot find in any style which makes sense since it is NOT showing up in any other section. Any ideas?
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,196
    4
    Default Re: Corridor section shows odd green box
    What does that area of the corridor show in an isometric or 3D view? It may be an issue where the assemblies are not targeting the correct data at an intersection.
    2017-09
    71
    Ah thanks for the hint. We found an anomaly 20 or so feet away - it was an area where it didn't have a target and it was creating a cone like surface. We fixed that and the section fixed itself. Yes!
    100 Club JeffClark's Avatar
    2002-07
    South Jersey
    153
    Yes! Thank you Opie.
    Once we saw it in the Iso 3D view, we were able to ID the bad spot and fix it. Then the weird cross section magically fixed itself!
  1. 2016: Trying to add datum to corridor and it shows up weird in sections
    By FabriCADed in forum AutoCAD Civil 3D - Sections
    Last Post: 2023-06-03, 02:41 AM
  2. Replies: 0
    Last Post: 2015-08-07, 03:58 PM
  3. Replies: 0
    Last Post: 2015-08-07, 02:11 PM
  4. Replies: 0
    Last Post: 2015-08-07, 02:06 PM
  5. 2012: Tables turning green - all green
    By FHull in forum AutoCAD Tables
    Last Post: 2013-03-11, 04:44 AM
Tags for this Thread
