Thread: Is there a way to make an assembly name?
    2009-11
    Raleigh, NC
    975
    Default Is there a way to make an assembly name?
    Is there a way to make an assembly name? Like a profile view name.
    I create a column to the left of the profile and I create manual text above the assembly. It would be very cool as I am adding more regions in between if I didnt have to keep those updated manually.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,196
    Default Re: Is there a way to make an assembly name?
    Create the text with a field with the assembly's name property. You can use the AutoLISP routine in the download file provided by Jeff_M in this Autodesk Forums post. The routine will help to automate that process.
    2009-11
    Raleigh, NC
    975
    Thanks Opie
  1. 2015: Howto set the name of the LandXML CrossSect as the name of the Corridor assembly used?
    By a.ghensi689507 in forum AutoCAD Civil 3D - General
    Last Post: 2015-12-22, 12:33 PM
  2. Replies: 9
    Last Post: 2013-12-10, 12:33 AM
  3. Replies: 0
    Last Post: 2013-02-12, 07:32 AM
  4. Replies: 10
    Last Post: 2006-12-28, 10:11 PM
  5. What's the best way to make a Door/Window Assembly
    By clintr in forum Revit Architecture - General
    Last Post: 2006-06-19, 02:06 PM
